Hello Epics community
This core was cause d by me. There is no problem with epics. Mark was using a file that I modified.
I am sorry for taking everyone's valuable time.
Sent from my iPhone
On Oct 9, 2014, at 4:04 PM, "Konrad, Martin" <[email protected]> wrote:
> Hi Mark,
>> If you can't, take a look at how much stack space your
>> Process1_routine subroutine needs, running out of stack space is one
>> possible cause for this kind of strange behaviour in addition to the
>> usual kinds of problems. A full stack trace for all threads when the
>> crash happens would also help us help you (type 'thread apply all bt'
>> in gdb).
> Keep in mind that the stack trace could be corrupted. You might want to
> run with a trivial subroutine for testing.
> In addition to that it's always a good idea to write a short test
> program that calls the subroutine function with some test values. You
> can run this test program with
> valgrind --tool=memcheck <your_test_program>
> to see if it is writing to memory it should not write to.
> Regards,
> Martin
> Martin Konrad
> Control System Engineer
> Facility for Rare Isotope Beams
> Michigan State University
> 640 South Shaw Lane
> East Lansing, MI 48824-1321, USA
> Tel. 517-908-7253
> Email: [email protected]
- RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
- Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
Re: TCP connection status : drvAsynIPPort Torsten Bögershausen
histogram record and CSS XY Graph [email protected]
<2014>
2025
2026
stumbled at the first softioc example HaveF
<2014>
2025
2026
