Hi:
Just as you produce the data for the "Y" axis on the IOC in a histogram record, you might want to generate the data for the "X" axis in a record on the IOC as well.
Then configure the XY Graph widget to show those X and Y records.
To generate arbitrary "X" waveforms on the IOC, you may be able to use a "compress" record fed by a calc that counts from your desired start to end value, but otherwise I've used a genSub/aSub record for that.
Kay
On Oct 13, 2014, at 9:48 AM, "[email protected]" <[email protected]>
wrote:
> Hi,
> I'm using a 'histogram' record to store some values:
> record(histogram,"$(P):noisefloor") {
> field(DTYP,"$(D)")
> field(DESC,"LTC2499 noise floor")
> field(SCAN,"1 second")
> field(SVL,"$(P):microvolt:CH0")
> field(ULIM,20)
> field(LLIM,-20)
> field(NELM,100)
> as you can see number of bin is 100 and values are from -20 to 20;
> I'm able to create a histogram on CSS starting from XY Graph widget, but
> X axis reports values from 0 to 100. Is there a script in order to display
> values from -20 to 20 ?
> If I set 'Minumum' and 'Maximum' properties of "Primary X Axis" to -20 and
> 20 the graph is empty because values are plotted by histogram index and not by histogram value... (e.g. value 0 -> position 50)
> Thanks in advance,
> Gennaro
> Gennaro Tortone
> INFN Napoli
> Italy
> tel: +39 81 676169
> "Computer Science is no more about computers
> than astronomy is about telescopes."
> - Edsger Dijkstra
- Re: histogram record and CSS XY Graph [email protected]
- histogram record and CSS XY Graph [email protected]
<2014>
2025
2026
<2014>
2025
2026
