1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: could it possible to get pv from another subnet?
To: "Hartman, Steven M." <[email protected]>
Date: Wed, 15 Oct 2014 10:55:17 +0800
@Steven Hartman
I just check the gateway solution. It need PC which has several network interface to handle IOCs
and clients.
The image below is a typical connection between 3 private networks:
gateway
As we all know, the PC with software is not as reliable as the router box(if I set the 202.201.1.4 to the PC instead of a router).
So, I guess, in my/your situation(ex: two private networks), if the gateway service is down, the whole pv under that gateway cannot
be seen in other private network. It seems very fragile. What do you think?
On Wed, Oct 15, 2014 at 9:26 AM, HaveF <[email protected]> wrote:
Thanks for all your comments.
Especially Steven Hartman, I suppose CA gateway is what I’m looking for.
The only reason I use the camonitor in other subnet is for simplifying
the question.
Thank you all again :-D
On Wed, Oct 15, 2014 at 1:15 AM, Hartman, Steven M. <[email protected]> wrote:
On Oct 14, 2014, at 9:27 AM, Mark S. Engbretson <[email protected]> wrote:
> The network topology is set up so that you *DON"T* normally have any sort of
> interaction between the 2 . . . . so why now do you need interaction between
> the 2?  What is so important that the camonitor system has to stay on that
> subnet instead of being put onto the other one?
I agree with Mark that HaveF would receive better responses if the request to tech-talk included a description of what they are trying to accomplish with this particular configuration. But I will jump in with a possible solution.
The network diagram in the initial post looks similar to a setup we have here at SNS. The accelerator controls network is in a private network. The individual beam line controls networks are in their own, separate private networks. On the controls network, there is a CA server (actually, many CA servers) which provides accelerator status PVs (beam energy, current, . . .) which is equivalent to your '192.168.1.200 CAS'. CA clients, equivalent to your '192.168.1.100 camonitor', on the beam line networks would like to be able to monitor some of these PVs.
The solution is a CA gateway on the equivalent of your 202.201.1.4 box which provides read-only access to the accelerator PVs, visible by the beam line clients.
http://www.aps.anl.gov/epics/extensions/gateway/index.php
Steven Hartman
[email protected]
Sincerely,
HaveF
Sincerely,
HaveF
Re: could it possible to get pv from another subnet? Hartman, Steven M.
could it possible to get pv from another subnet? HaveF
RE: could it possible to get pv from another subnet? Mark Rivers
RE: could it possible to get pv from another subnet? Mark S. Engbretson
Re: could it possible to get pv from another subnet? HaveF
Prev: Re: could it possible to get pv from another subnet? HaveF
Next: Re: could it possible to get pv from another subnet? HaveF
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
