1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS on vxWorks
To: <[email protected]>
Date: Wed, 15 Oct 2014 18:39:43 +0530
We are trying to put EPICS on target running vxWorks 6.9.
We could build EPICS Base 3-14-12-4 for
CROSS_COMPILER_TARGET_ARCHS = vxWorks-ppc32
But when I am trying to build the same for :
CROSS_COMPILER_TARGET_ARCHS = vxWorks-ppc604_long
we are getting following errors during the  ‘make’ process:
C:/WindRiver/vxworks-6.9/target/h/stdio.h:349: warning: 'int voprintf(int (*)(..
.), _Vx_usr_arg_t, const char*, __va_list_tag*)' is deprecated (declared at C:/W
indRiver/vxworks-6.9/target/h/stdio.h:347)
../../../src/libCom/fdmgr/fdmgr.cpp: In member function 'virtual epicsTimerNotif
y::expireStatus timerForOldFdmgr::expire(const epicsTime&)':
../../../src/libCom/fdmgr/fdmgr.cpp:154: error: unable to find a register to spill in class 'FLOAT_REGS'
../../../src/libCom/fdmgr/fdmgr.cpp:154: error: this is the insn:
(insn:HI 16 15 17 2 ../../../src/libCom/fdmgr/fdmgr.cpp:153 (set (reg:DF 126 [ D.11716.delay ])
        (mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
                (const_int 8 [0x8])) [15 D.11716.delay+0 S8 A64])) 336 {*movdf_h
ardfloat32} (expr_list:REG_EQUIV (mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
        (nil)))
../../../src/libCom/fdmgr/fdmgr.cpp:154: confused by earlier errors, bailing out
make[3]: *** [fdmgr.o] Error 1
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.vxWorks-ppc604_
long'
make[2]: *** [install.vxWorks-ppc604_long] Error 2
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
make: *** [src.install] Error 2
There is following code at the specified line no (154) of file fdmgr.cpp:
epicsTimerNotify::expireStatus timerForOldFdmgr::expire ( const epicsTime & )
    (*this->pFunc) (this->pParam);
    return noRestart;
Any clues to solve this issue will be of help.
Thanks & Regards,
Amit.
Re: EPICS on vxWorks Andrew Johnson
Prev: Re: could it possible to get pv from another subnet? Hartman, Steven M.
Next: AsynPortDriver setting DRVH of ao? Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: how to add a variable in asyn command Eric Norum
Next: Re: EPICS on vxWorks Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
