1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AsynPortDriver setting DRVH of ao?
To: "'Florian Feldbauer'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 15 Oct 2014 15:00:42 +0000
Hi Florian,
This can easily be done by using 2 additional records.
Define a new asynFloat64 parameter in your driver which is the maximum voltage that you read back from the remote control interface.  This could have a drvInfo field of MAX_VOLTAGE, for example.  Make sure your driver sets the flag that registers it as an interrupt source on the asynFloat64 interface.
Your database would then look like this:
record(ai, "$(P)$(R)MaxVoltage")
    field(DTYP, "asynFloat64")
    field(INP, "@asyn($(PORT),0,1)MAX_VOLTAGE
    field(SCAN, "I/O Intr")
    field(FLNK, "$(P)$(R)SetMaxVoltage")
record(ao, "$(P)$(R)SetMaxVoltage")
    field(DOL, "$(P)$(R)MaxVoltage NPP")
    field(OMSL, "closed_loop")
    field(OUT, "$(P)$(R)Voltage.DRVH NPP")
So the MaxVoltage will process whenever your driver sets a new value for the MAX_VOLTAGE parameter.  That will cause the SetMaxVoltage record to process, which copies the value of MaxVoltage to the DRVH field of your existing Voltage ao record.
-----Original Message-----
Sent: Wednesday, October 15, 2014 8:11 AM
To: Mark Rivers; EPICS Tech Talk
Subject: AsynPortDriver setting DRVH of ao?
Hey Mark,
I'm using the asynPortDriver for some of my device support routines.
Now we have a power supply were the maximum voltage can be limited via a
poti.
The actual value can be read out via the remote control interface.
We would like to use this value for the DRVH field of the ao records
used to set the output voltage.
Is it possible (e.g. during initialization) to set the DRVH fields via
the asynPortDriver?
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
Prev: AsynPortDriver setting DRVH of ao? Florian Feldbauer
Next: RE: TCP connection status : drvAsynIPPort Patel Jignesh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
