Subject: |
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved] |
Heinz Junkes <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Thu, 16 Oct 2014 12:19:38 +0200 |
Adding
OP_SYS_LDLIBS += -lxml2
to
RELEASE_LIBS.local
solves the problem.
Heinz
On 16 Oct 2014, at 07:57, Heinz Junkes <[email protected]> wrote:
> Hi Lewis,
> I build it from source.
> Setting the env-vars like this:
> h1:iocSimDetector junkes$ export DYLD_LIBRARY_PATH=/opt/local
> h1:iocSimDetector junkes$ export LD_LIBRARY_PATH=/opt/local
> leads to the same error:
> h1:iocSimDetector junkes$ ../../bin/darwin-x86/simDetectorApp st.cmd.darwin
> Referenced from: /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
> Expected in: flat namespace
> in /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
> Trace/BPT trap: 5
> Heinz
> On 15 Oct 2014, at 22:59, J. Lewis Muir <[email protected]> wrote:
>> On 10/15/14 3:44 PM, Heinz Junkes wrote:
>>> _xmlFree can be found in /opt/local/libxml2.dylib
>>> 00000000000f2b28 D _xmlFree
>>> Pointing LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to this dir will not
>>> solve the problem:
>>> LD_LIBRARY_PATH=/opt/local/lib
>>> DYLD_LIBRARY_PATH=/opt/local/lib
>>> Any idea?
>> Hi, Heinz.
>> Did you build from source, or are you using the pre-built binary
>> version? If you're using the pre-built binary, then there is likely
>> something wrong with it since it should include any libraries it needs.
>> Moving beyond that, you said the symbol _xmlFree can be found in
>> /opt/local/libxml2.dylib, but then you set LD_LIBRARY_PATH and
>> DYLD_LIBRARY_PATH to /opt/local/lib. Note that the path ends in a
>> directory named "lib". If the libxml2.dylib library is in /opt/local,
>> then you'd need to set LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to
>> /opt/local, not /opt/local/lib.
>> Lewis
smime.p7s
Description: S/MIME cryptographic signature
- RE: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved] Mark Rivers
- areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
- Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree J. Lewis Muir
StreamDevice "in" command disturbed by out command haquin
<2014>
2025
2026
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
<2014>
2025
2026
