Hello Kay, Thank you for the quick response. Sorry for the wrong screen shot. I used the link http://192.168.2.57:8080/apps/webopi and got the same error. Tomcat did unpack the webopi.war into apps#webopi directory. I even removed the apps#webopi directory and found that if I try to access the url, the apps#webopi directory will be created. I checked the log files and found that it complains can't find file: java.io.FileNotFoundException: /usr/share/tomcat7/css_rap.ini (No such file or directory) After copy the css_rap.ini into the /usr/share/tomcat7, the error message disappeared. But the http status 404 error are still there (attached snapshot is after I copied the css_rap.ini). I have attached the logs file and hope you can find something wrong. Your kind help is appreciated. - Tom > From: [email protected]> To: [email protected]> CC: [email protected]> Subject: Re: webopi -- http status 404 error > Date: Thu, 16 Oct 2014 20:01:09 +0000 > > > On Oct 16, 2014, at 2:00 PM, Tom Smart < [email protected]<mailto: [email protected]>> > wrote: > 3. chown tomcat7.tomcat7 /var/lib/tomcat7/webapps/apps#webopi.war > And when I used the following url > http://192.168.2.57:8080/apps/webopi > > or > http://localhost:8080/app/webopi > > The screenshot showed "../app/.." as well, but you copied it into webapps/apps#webopi.war, so the link must also use "apps/webopi". > > Did tomcat unpack the webopi.war file into a webopi/ directory? > Check the tomcat/logs/* files for error messages. > > > My java version is "1.6.0_32". > I think you need Java 7. > > -Kay
Oct 16, 2014 12:19:40 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/apps#webopi.war
Oct 16, 2014 12:19:43 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
WARNING: System property org.csstudio.rap.preference is not set, try user.home.
SEVERE: Server Side Preference loading failed.
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:140)
at java.io.FileInputStream.<init>(FileInputStream.java:96)
at org.csstudio.rap.core.preferences.ServerPreferenceNode.loadProperties(ServerPreferenceNode.java:436)
at org.csstudio.rap.core.preferences.ServerPreferenceNode.load(ServerPreferenceNode.java:419)
at org.csstudio.rap.core.preferences.ServerPreferenceNode.<init>(ServerPreferenceNode.java:84)
at org.csstudio.rap.core.preferences.ServerPreferenceFactory.create(ServerPreferenceFactory.java:9)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.createNode(PreferenceServiceRegistryHelper.java:190)
at org.eclipse.core.internal.preferences.PreferencesService.createNode(PreferencesService.java:387)
at org.eclipse.core.internal.preferences.RootPreferences.getChild(RootPreferences.java:63)
at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:101)
at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:90)
at org.eclipse.core.internal.preferences.PreferencesService$5.run(PreferencesService.java:623)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.preferences.PreferencesService.getNodes(PreferencesService.java:607)
at org.eclipse.core.internal.preferences.PreferencesService.getBoolean(PreferencesService.java:477)
at org.csstudio.platform.libs.epics.EpicsPlugin.installPreferences(EpicsPlugin.java:224)
at org.csstudio.platform.libs.epics.EpicsPlugin.start(EpicsPlugin.java:155)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
at org.csstudio.rap.core.preferences.ServerPreferenceNode.createChild(ServerPreferenceNode.java:211)
at org.csstudio.rap.core.preferences.ServerPreferenceNode.getChild(ServerPreferenceNode.java:295)
at org.csstudio.rap.core.preferences.ServerPreferenceNode.node(ServerPreferenceNode.java:467)
Oct 16, 2014 12:56:05 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/apps#webopi3.3.war
Oct 16, 2014 12:56:06 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
Oct 16, 2014 4:23:10 PM org.apache.catalina.startup.HostConfig checkResources
INFO: Undeploying context [/apps/webopi]
Oct 16, 2014 4:23:11 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:23:13 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
Oct 16, 2014 4:36:45 PM org.apache.catalina.startup.HostConfig checkResources
Oct 16, 2014 4:36:46 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:36:48 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
Oct 16, 2014 4:38:28 PM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:28 PM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service Catalina
Oct 16, 2014 4:38:30 PM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:30 PM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:35 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:35 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 470 ms
Oct 16, 2014 4:38:35 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Oct 16, 2014 4:38:35 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.28
Oct 16, 2014 4:38:35 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/docs.xml
Oct 16, 2014 4:38:41 PM org.apache.catalina.util.SessionIdGenerator createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [6,442] milliseconds.
Oct 16, 2014 4:38:41 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/examples.xml
Oct 16, 2014 4:38:42 PM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: http://java.sun.com/jstl/core_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/core is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/core is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/fmt_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/fmt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/fmt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/functions is already defined
INFO: TLD skipped. URI: http://jakarta.apache.org/taglibs/standard/permittedTaglibs is already defined
INFO: TLD skipped. URI: http://jakarta.apache.org/taglibs/standard/scriptfree is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/sql_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/sql is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/sql is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/xml_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/xml is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/xml is already defined
Oct 16, 2014 4:38:42 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/manager.xml
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/host-manager.xml
Oct 16, 2014 4:38:42 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:38:44 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:38:47 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /var/lib/tomcat7/webapps/ROOT
Oct 16, 2014 4:38:47 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:47 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 12407 ms
catalina.out
Description: Binary data
Oct 16, 2014 4:38:28 PM org.apache.catalina.core.ApplicationContext log
INFO: SessionListener: contextDestroyed()
INFO: ContextListener: contextDestroyed()
Oct 16, 2014 4:38:42 PM org.apache.catalina.core.ApplicationContext log
INFO: ContextListener: contextInitialized()
INFO: SessionListener: contextInitialized()
INFO: ContextListener: attributeAdded('org.apache.jasper.compiler.TldLocationsCache', 'org.apache.jasper.compiler.TldLocationsCache@157bfb')
192.168.2.57 - - "-" 400 -
192.168.2.57 - - [16/Oct/2014:11:57:44 -0400] "GET / HTTP/1.1" 200 1895
192.168.2.57 - - [16/Oct/2014:11:57:44 -0400] "GET /favicon.ico HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:11:57:47 -0400] "GET /docs/ HTTP/1.1" 200 14949
192.168.2.57 - - [16/Oct/2014:11:57:47 -0400] "GET /docs/images/tomcat.gif HTTP/1.1" 200 2066
192.168.2.57 - - [16/Oct/2014:11:57:47 -0400] "GET /docs/images/asf-logo.gif HTTP/1.1" 200 7279
192.168.2.57 - - [16/Oct/2014:11:57:50 -0400] "GET /examples/ HTTP/1.1" 200 1179
192.168.2.57 - - [16/Oct/2014:11:57:53 -0400] "GET /manager/html HTTP/1.1" 401 2486
192.168.2.57 - - [16/Oct/2014:11:58:08 -0400] "GET /examples/websocket HTTP/1.1" 302 -
192.168.2.57 - - [16/Oct/2014:11:58:08 -0400] "GET /examples/websocket/ HTTP/1.1" 200 1219
192.168.2.57 - - [16/Oct/2014:11:58:09 -0400] "GET /examples/websocket/chat.html HTTP/1.1" 200 3855
192.168.2.57 - - [16/Oct/2014:11:58:09 -0400] "GET /examples/websocket/chat HTTP/1.1" 101 -
192.168.2.57 - - [16/Oct/2014:11:58:11 -0400] "GET /examples/websocket/echo.html HTTP/1.1" 200 5456
192.168.2.57 - - [16/Oct/2014:11:58:19 -0400] "GET /examples/servlets HTTP/1.1" 302 -
192.168.2.57 - - [16/Oct/2014:11:58:19 -0400] "GET /examples/servlets/ HTTP/1.1" 200 5222
192.168.2.57 - - [16/Oct/2014:11:58:20 -0400] "GET /examples/servlets/images/execute.gif HTTP/1.1" 200 1242
192.168.2.57 - - [16/Oct/2014:11:58:20 -0400] "GET /examples/servlets/images/code.gif HTTP/1.1" 200 292
192.168.2.57 - - [16/Oct/2014:11:58:20 -0400] "GET /examples/servlets/images/return.gif HTTP/1.1" 200 1231
192.168.2.57 - - [16/Oct/2014:11:58:23 -0400] "GET /examples/servlets/servlet/HelloWorldExample HTTP/1.1" 200 347
192.168.2.57 - - [16/Oct/2014:11:58:26 -0400] "GET /examples/servlets/servlet/RequestInfoExample HTTP/1.1" 200 664
0:0:0:0:0:0:0:1 - - [16/Oct/2014:12:24:07 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
0:0:0:0:0:0:0:1 - - [16/Oct/2014:12:24:07 -0400] "GET /favicon.ico HTTP/1.1" 404 988
0:0:0:0:0:0:0:1 - - [16/Oct/2014:12:24:08 -0400] "GET /favicon.ico HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:13:29:29 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:30:07 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:13:35:25 -0400] "GET /app/webopi HTTP/1.1" 404 985
192.168.2.57 - - [16/Oct/2014:13:35:25 -0400] "-" 400 -
192.168.2.57 - - [16/Oct/2014:13:30:07 -0400] "-" 400 -
192.168.2.57 - - [16/Oct/2014:13:52:40 -0400] "GET /app/webopi HTTP/1.1" 404 985
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:52:47 -0400] "GET /app/webopi HTTP/1.1" 404 985
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:53:12 -0400] "GET / HTTP/1.1" 200 1895
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:53:34 -0400] " ¤  Â±c 4Ã?3¯PRÃ?Â?ëûÃ?]ª#Ã?Ã?&mT>Â?Ã?9¶kÃ?Â? FÃ? " 400 -
192.168.2.57 - - [16/Oct/2014:16:22:30 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:23:11 -0400] "GET /apps/webopi HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:16:26:18 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:26:38 -0400] "GET / HTTP/1.1" 304 -
192.168.2.57 - - [16/Oct/2014:16:26:47 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:28:36 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:30:09 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:30:09 -0400] "GET /favicon.ico HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:16:38:50 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
- webopi -- http status 404 error Tom Smart
- Re: webopi -- http status 404 error Kasemir, Kay
csstudio RAP applications Xinyu.Wu
<2014>
2025
2026
<2014>
2025
2026
