1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: csstudio RAP applications
To: "<[email protected]> " <[email protected]>
Cc: "<[email protected]>" <[email protected]>
Date: Fri, 17 Oct 2014 12:52:04 +0000
Hi:
Since the CSS build was moved to use tycho/maven, the RAP build has been broken.
Last I tried, it would compile, result in a *.war file, but that *.war file would not actually work with tomcat, application doesn't start.
-Kay
On Oct 17, 2014, at 12:02 AM, <[email protected]<mailto:[email protected]>>
 wrote:
I’m trying to run some RAP applications from csstudio. But getting loads of errors. Is there any documentation on how to build and run RAP application?
Some basic questions are versions requirements:
- which version of eclipse?
- which version of RAP?
- which version of equinox?
- which version of Jetty?
I tried with
- Eclipse Indego
And added the following to the target platform:
- RAP 1.5
- the above requires Jetty, so I also added http://run-jetty-run.googlecode.com/svn/trunk/updatesite/
- the equinox from cs-studio/core/plugins/org.csstudio.rap.core/third_party_plugins/RAP_GEF_1.5.0/
Once I’ve done the target platform, all the RAP plugins compile. But when I ‘Launch a RAP Application’ from org.csstudio.alarm.beast.ui.rap/MANIFEST.MF, it fails with many errors.
Xinyu WU
ASKAP Computing
Australia Telescope National Facility
CSIRO Astronomy and Space Science
phone: +61 2 9372 4727
postal: PO Box 76 Epping, NSW. 1710
csstudio RAP applications Xinyu.Wu
Prev: Re: StreamDevice "in" command disturbed by out command haquin
Next: asyn R4-24 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: csstudio RAP applications Xinyu.Wu
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
