Folks,
asyn R4-24 is now available. Links to the new documentation, release notes and tar file can be found here:
http://www.aps.anl.gov/epics/modules/soft/asyn/
asyn is also available via the APS Subversion repository here:
https://svn.aps.anl.gov/epics/asyn/
These are the items from the R4-24 release notes:
drvAsynIPPort.c
Added capability to specify the local port that the server should use for the connection. Normally the local host chooses a random local port that it binds to and passes to the server. There are a few servers that only accept a specific local port or range of local ports, for which this capability is required. The new syntax is:
<host>:<port>[:localPort] [protocol]
For example
164.54.160.100:5000:10101 UDP
where 10101 is the optional local port number.
devEpics
Fixed all initialization routines so that if there is an error they do the following:
Call recGblSetSevr(precord,LINK_ALARM,INVALID_ALARM)
Set precord->pact=1
return(INIT_ERROR), where INIT_ERROR=-1
Thanks to Nick Rees for these fixes.
Many source files
Fixed problem with location of #define epicsExportSharedSymbols and/or #include <epicsExport.h>. In previous versions these were placed immediately before the #include statements defining symbols for that source file . However, this was incorrect, they must be placed before all of the #include statements defining symbols for that DLL . This mistake causes the same symbol being defined with both dllExport and dllImport when building the DLL. The Visual Studio compiler does not even warn about this error, but it produces a fatal error with the GCC compiler under Cygwin.
Re: csstudio RAP applications Kasemir, Kay
areaDetector ADCore and ADBinaries R2-1 released Mark Rivers
<2014>
2025
2026
<2014>
2025
2026
