I am trying to compile on windows.
I downloaded the MinGW bundle and set the EPICS_HOST_ARCH to WIN32-X86-mingw.
When I first run make on base-3.14.12.4
I get and error that direct.h could not be found.
I fix this by setting C_INCLUDE_PATH to /c/MinGW/include where there is a
direct.h file.
But then I got the following error
g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I.
-I../
O.Common -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/pos
ix -I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/bucketLib -I.
./../../src/libCom/ring -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/
libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../sr
c/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../.
./../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClie
nt -I../../../src/libCom/macLib -I../../../src/libCom/misc
/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/lib
Com/tsDefs -I../../../include/os/WIN32 -I../../../include
../../../src/li
bCom/fdmgr/fdmgr.cpp
In file included from ../../../src/libCom/osi/epicsTime.h:19,
from ../../../src/libCom/fdmgr/fdManager.h:27,
from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
../../../src/libCom/osi/os/WIN32/osdTime.h:21: error: redefinition of
`struct ti
mespec'
/usr/include/sys/types.h:76: error: previous definition of `struct timespec'
In file included from ../../../src/libCom/osi/os/WIN32/osdSock.h:23,
from ../../../src/libCom/osi/osiSock.h:21,
from ../../../src/libCom/fdmgr/fdManager.h:28,
/usr/lib/gcc/i686-pc-msys/3.4.4/../../../../include/w32api/winsock2.h:103:2:
war
ning: #warning "fd_set and associated macros have been defined in sys/types.
This may cause runtime problems with W32 sockets"
make[3]: *** [fdmgr.o] Error 1
make[3]: Leaving directory `/c/base-3.14.12.4/src/libCom/O.WIN32-x86-mingw'
make[2]: *** [install.WIN32-x86-mingw] Error 2
make[2]: Leaving directory `/c/base-3.14.12.4/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/c/base-3.14.12.4/src'
make: *** [src.install] Error 2
Any idea what is going wrong?
Is there other preferred way to compile EPICS on windows XP 32bit?
Thanks in advance for you help,
Zunbeltz
- Re: compile on Windows XP with MinGW Mark Rivers
Re: Problem with CSS archive engine 龙巍
Re: Interface Labview and EPICS Carsten Winkler
<2014>
2025
2026
Re: Interface Labview and EPICS Dale L. Brewe
<2014>
2025
2026
