1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyndriver : Multiple drvAsynIPPort
To: Patel Jignesh <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 22 Oct 2014 21:45:53 +0000
> In this case  I will have problem with registering the port and interfaces for my driver. So will above method will work ? or please suggest the good way to tackle this problem.
I don't understand why you will have a problem registering the port and interfaces for your driver.  The fact that your S7 driver is now talking to 2 underlying asynIPPort drivers should not affect registering your driver and interfaces.
Maybe I am missing something?
From: [email protected] [[email protected]] on behalf of Patel Jignesh [[email protected]]
Sent: Wednesday, October 22, 2014 10:19 AM
To: [email protected]
Subject: asyndriver : Multiple drvAsynIPPort
For asyn based Siemens PLC driver development, currently I am using IP Port driver with below configuration and primary development is working good with block data transfer.
drvAsynIPPortConfigure("PLC_SAMPLE_CPU_2000", "10.130.1.109:2000", 0, 0, 1)
drvS7synConfigure("P0_cfg", "PLC_SAMPLE_CPU_2000", 128, 66, 50, "PLCSample 0")
Now to handle the redundant PLC configuration, I have to connect to two PLCs, and I will process/pass the data from any one plc out of two, so I am thinking like, to open two connection using IPPort driver and use them both in my driver like below,
drvAsynIPPortConfigure("PLC_SAMPLE_CPU0_2000", "10.130.1.109:2000", 0, 0, 1)
drvAsynIPPortConfigure("PLC_SAMPLE_CPU1_2000", "10.130.1.110:2000", 0, 0, 1)
drvS7synConfigure("P0_cfg","PLC_SAMPLE_CPU0_2000", "PLC_SAMPLE_CPU1_2000", 128, 66, 50, "PLCSample 0")
Thanks and best regards,
Jignesh
[iterlogo]<http://www.iter.org/>
Jignesh PATEL
Control Systems Integration Technician
CODAC Section
ITER Organization, Building 72/286, CHD, Control System Division
Route de Vinon-sur-Verdon - CS 90 046 - 13067 St Paul Lez Durance Cedex – France
Phone: +33 4 42 17 84 72
Get the latest ITER news on http://www.iter.org/whatsnew
JPEG image
asyndriver : Multiple drvAsynIPPort Patel Jignesh
Prev: Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Next: Re: order of rules in Makefile Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: asyndriver : Multiple drvAsynIPPort Patel Jignesh
Next: Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
