1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Discussion about licenses, copyrights, business, and source code
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Thu, 23 Oct 2014 18:42:26 -0500
On 10/23/14 2:58 AM, Johnson, Andrew N. wrote:
>> On Oct 23, 2014, at 00:07, J. Lewis Muir <[email protected]> wrote:
>> See:
>>  http://www.gnu.org/licenses/gpl-faq.html#GPLAndPlugins
>> To me, that supports what I said.
> Read the following FAQ points as well, there are subtle distinctions
> between whether your main application is GPL or your plugin is GPL,
> and I think the example you pointed to was for a non-GPL plugin to a
> GPL application.
Hi, Andrew.
Hmm...I don't see the subtle distinctions.  I see distinctions for
linking and whatnot, but I don't see distinctions for the "fork and
exec" case.  I very much so respect your opinion on this, so I'd really
like to understand.  There are three FAQ questions that talk about
plug-ins and they all start with a paragraph that says there are no
special requirements if the program uses fork and exec to invoke the
plug-ins.  Here are the three questions and the first paragraph of each
answer:
* If I write a plug-in to use with a GPL-covered program, what
  requirements does that impose on the licenses I can use for
  distributing my plug-in?
  It depends on how the program invokes its plug-ins. If the program
  uses fork and exec to invoke plug-ins, then the plug-ins are separate
  programs, so the license for the main program makes no requirements
  for them.
* Can I apply the GPL when writing a plug-in for a non-free program?
  If the program uses fork and exec to invoke plug-ins, then the
  plug-ins are separate programs, so the license for the main program
  makes no requirements for them. So you can use the GPL for a plug-in,
  and there are no special requirements.
* Can I release a non-free program that's designed to load a GPL-covered
  plug-in?
  It depends on how the program invokes its plug-ins. For instance, if
  the program uses only simple fork and exec to invoke and communicate
  with plug-ins, then the plug-ins are separate programs, so the license
  of the plug-in makes no requirements about the main program.
So, I'm not getting it.  What am I missing?!  Thanks for your patience.
Lewis
Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
Re: Discussion about licenses, copyrights, business, and source code J. Lewis Muir
Prev: Re: compile on Windows XP with MinGW Mark Rivers
Next: Re: Focus deadlock nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Next: Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
