1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Discussion about licenses, copyrights, business, and source code
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 22 Oct 2014 17:07:22 -0500
On 10/22/14 4:45 PM, Johnson, Andrew N. wrote:
> Actually in many cases you don’t have to make your changes
> *publicly* available, you only have to make your exact modified
> source available to anyone to whom you give a copy of the program
> binary, so that they have the same rights and ability that you
> do to study and further modify it according to their needs. The
> public source requirement is only specifically required if
> you put a copy of a binary on a public network server; see
> http://www.gnu.org/licenses/gpl-faq.html#AnonFTPAndSendSources and
> section 6(d) of GPLv3 for details.
Hi, Andrew.
Right, I didn't realize this.  I read the GPL FAQ link Martin Konrad
referenced in his reply which confirms this.  The FAQ entry does say,
though, that the person or company to whom you give the source code is
free to publish it, so I wouldn't base my business on keeping the source
code private for this case.
> I would be careful with making assumptions about using “plug-in”
> programs, the GPLv3 definition for Corresponding Source "includes
> interface definition files associated with source files for the work,
> and the source code for shared libraries and dynamically linked
> subprograms that the work is specifically designed to require,
> such as by intimate data communication or control flow between
> those subprograms and other parts of the work.” This means that
> “intimate” inter-program communication could also require your
> program to be released under the GPL in some cases.
See:
  http://www.gnu.org/licenses/gpl-faq.html#GPLAndPlugins
To me, that supports what I said.
Lewis
Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
Re: Discussion about licenses, copyrights, business, and source code J. Lewis Muir
Prev: Re: order of rules in Makefile Johnson, Andrew N.
Next: Re: Discussion about licenses, copyrights, business, and source code Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Next: Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
