1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Hytec 8402 DAC memory mode on a TVME200 IP carrier
To: EPICS <[email protected]>
Date: Fri, 31 Oct 2014 09:54:51 -0500
Has anyone successfully used the Hytec 8402 DAC in memory mode with a TVME200 IP carrier?
In the course of debugging another problem, I tried running a Hytec 8402 DAC in memory mode on a TVME200 IP carrier. I could not get it to work. Register mode worked on a TVME200. And I did get both modes (register and memory) working with a SBS VIPC616 IP carrier.
I was briefly in contact with Jim Chen from Hytec on this, but since the Hytec problem was tangential to the original problem that I was investigating, I did not pursue it with him.
Ron
Prev: RE: asynError IOC Message Mark Rivers
Next: waveform with single element Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Tektronix DMM 4050 device support Hovanes Egiyan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
