1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: read waveform data using ca_create_subscription
To: tech-talk <[email protected]>
Date: Wed, 5 Nov 2014 09:55:41 +0800 (GMT+08:00)
Thank Andrew, Bruce and Yong! Andrew has pointed out the mistake I made. It's really hard to find it out. It's working smoothly now. Thank you all!
Cheers,
Xuan
> -----原始邮件-----
> 发件人: "Andrew Johnson" <[email protected]>
> 发送时间: 2014年11月5日 星期三
> 收件人: "吴煊" <[email protected]>
> 抄送:
> 主题: Re: ca problem
> Hi Xuan,
> On 11/04/2014 06:05 AM, 吴煊 wrote:
> > I've post a email to tech-talk, but received no reply. I came
> > across a weird problem. That's if I create less than 41 channels,
> > the program works fine. If I create more than 42 channels, it will
> > segment fault. I suspect that is there any limitation in ca client
> > tools. Could you help me getting rid of this? Many thanks in advance.
> > The simple code and db is in the attachment.
> The problem is in your code, in both the simplified test.c that you sent
> me and your original archive.c file. This variable definition
> 	char chName[MAX_STRING][CH_NUM];
> does not match your code that uses it:
> 	sprintf(chName[index], "wf%d", index+1);
> 	stat=ca_create_channel(chName[index],NULL,NULL,CA_PRIORITY_DEFAULT,&pv[index].channel);
> The code using it would need to be this:
> 	sprintf(&chName[0][index], "wf%d", index+1);
> 	stat=ca_create_channel(&chName[0][index],NULL,NULL,CA_PRIORITY_DEFAULT,&pv[index].channel);
> which does not seg-fault for me, unlike your original.
> However you don't actually need to keep the channel names in memory
> after you have passed them to ca_create_channel(), so you could replace
> the lines above with these and the result also works:
> 	char chName[MAX_STRING];
> 	sprintf(chName, "wf%d", index+1);
> 	stat=ca_create_channel(chName,NULL,NULL,CA_PRIORITY_DEFAULT,&pv[index].channel);
> You can always get the associated channel name from the CA chid
> afterwards using ca_name(pv[index].channel).
> Hope this helps,
> - Andrew
> People everywhere confuse what they read in newspapers with news.
> -- A. J. Liebling
Prev: Re: Sequencer: are variables shared? Damiano Bortolato
Next: catools (caget/caput/camonitor) and locale settings from the environment Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: read waveform data using ca_create_subscription Bruce Hill
Next: Re: Tektronix DMM 4050 device support Hovanes Egiyan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
