1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record processing during iocInit?
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 05 Nov 2014 11:54:42 +0100
What record type are you using?
SEVR=INVALID and STAT=UDF mean that the record's value is undefined.
If you are processing an undefined output record, its value will usually still be undefined after processing, so SEVR/STAT will remain INVALID/UDF. If you are processing an input record using PINI=YES, usually its value will be retrieved, so that the records get defined and the status is reset. If your input record reads using ChannelAccess (from a remote record), it will still be undefined, as PINI processing happens before ChannelAccess is started.
A better way to trace processing is setting the TPRO ("trace processing") field of your record to "1". This will make it print a line on the console when it processes.
HTH,
~Ralph
On 05/11/2014 11:36, Jörn Wüstenfeld wrote:
I have a problem of understanding the initialization of databaserecords during
iocInit. If I set the field PINI to YES, i would expect accordng to the
documentation, that the record gets processed once during iocInit. But it dos
not as a call to dbpr with the record name gives SEVR: Invalid.
Only after triggering the record with dbtr the revcord gets processed.
I'm using EPICS base 3.14.12.4 on an arm Platform. But I have seen the same
behaviour on an x86_64 machine.
Is my understanding of the documentation wrong, or do I need additional fields
to be set to get the record processed during init?
Jörn Wüstenfeld
Record processing during iocInit? Jörn Wüstenfeld
Prev: Record processing during iocInit? Jörn Wüstenfeld
Next: Re: NaN and analog records Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Record processing during iocInit? Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
