1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record processing during iocInit?
To: [email protected]
Date: Wed, 05 Nov 2014 13:38:14 +0100
Hi Jörn,
To see if a record has processed since reboot better look at the time stamp instead of the severity.
Dirk
On 05.11.2014 11:36, Jörn Wüstenfeld wrote:
I have a problem of understanding the initialization of databaserecords during
iocInit. If I set the field PINI to YES, i would expect accordng to the
documentation, that the record gets processed once during iocInit. But it dos
not as a call to dbpr with the record name gives SEVR: Invalid.
Only after triggering the record with dbtr the revcord gets processed.
I'm using EPICS base 3.14.12.4 on an arm Platform. But I have seen the same
behaviour on an x86_64 machine.
Is my understanding of the documentation wrong, or do I need additional fields
to be set to get the record processed during init?
Jörn Wüstenfeld
Re: Record processing during iocInit? Jörn Wüstenfeld
Prev: Re: NaN and analog records Benjamin Franksen
Next: Re: NaN and analog records Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record processing during iocInit? Ralph Lange
Next: Re: Record processing during iocInit? Jörn Wüstenfeld
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
