Does the expected value of the reading for that SI record depend on some other output record having already processed? If so, that can explain the failure during PINI because the SI record may have processed before the required output record. If this is the problem then you may be able to fix it by using the PHAS field to control the order in which records with PINI process.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jörn Wüstenfeld
Sent: Thursday, November 06, 2014 6:50 AM
To: [email protected]
Subject: Re: Record processing during iocInit?
The result, after switching on the debug message in snmp is:
_main_: Process CRPC:HZDR:VME:CR1:psSerial
2014/11/06 12:51:39 devSnmp SI read error 'CRPC:HZDR:VME:CR1:psSerial' : oid
has no valid reading
Some others show the same error message, but later during scanning return
reasonable results.
Jörn
- Re: Record processing during iocInit? Andrew Johnson
- Record processing during iocInit? Jörn Wüstenfeld
- Re: Record processing during iocInit? Jörn Wüstenfeld
- RE: Record processing during iocInit? Dalesio, Leo
Re: NaN and analog records Benjamin Franksen
<2014>
2025
2026
<2014>
2025
2026
