1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record processing during iocInit?
To: <[email protected]>
Date: Thu, 6 Nov 2014 09:33:46 -0600
On 11/06/2014 08:10 AM, Mark Rivers wrote:
> Does the expected value of the reading for that SI record depend on
> some other output record having already processed? If so, that can
> explain the failure during PINI because the SI record may have processed
> before the required output record. If this is the problem then you may
> be able to fix it by using the PHAS field to control the order in which
> records with PINI process.
You can also set PINI to RUNNING to have the records processed at the
very end of iocInit, although even then the network connections (e.g. CA
links or other network-based I/O) might not yet have been completed.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Record processing during iocInit? Jörn Wüstenfeld
Re: Record processing during iocInit? Jörn Wüstenfeld
RE: Record processing during iocInit? Dalesio, Leo
RE: Record processing during iocInit? Mark Rivers
Prev: RE: Record processing during iocInit? Mark Rivers
Next: Re: Record processing during iocInit? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
