1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Permissible in C to call CA I/O functions from callback?
To: [email protected]
Date: Fri, 14 Nov 2014 10:45:24 -0600
On 11/6/14 5:11 PM, Andrew Johnson wrote:
> It is permissible to call most non-blocking CA functions such as
> ca_get(), ca_get_callback, ca_put(), ca_put_callback() etc., but not
> ca_poll(), ca_pend_io() or ca_pend_event().
> If you look through the CA Reference manual, those routines that can
> return the code ECA_EVDISALLOW are not permitted within a callback.
Hi, Andrew.
Is it permissible to call ca_flush_io within a callback?  (It's not
marked as returning ECA_EVDISALLOW in the CA Reference manual.)
Thanks!
Lewis
Re: Permissible in C to call CA I/O functions from callback? Andrew Johnson
Permissible in C to call CA I/O functions from callback? J. Lewis Muir
Prev: Re: Can pvTimeGetCurrentDouble fail to set its argument? Benjamin Franksen
Next: Re: Permissible in C to call CA I/O functions from callback? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Permissible in C to call CA I/O functions from callback? Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
