1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Permissible in C to call CA I/O functions from callback?
To: <[email protected]>
Date: Thu, 6 Nov 2014 17:11:06 -0600
Hi Lewis,
On 11/06/2014 04:51 PM, J. Lewis Muir wrote:
> Is it permissible, in a C program using the EPICS CA client library
> using a preemptive CA context, to call CA functions that perform I/O
> from a user-supplied callback function?
It is permissible to call most non-blocking CA functions such as
ca_get(), ca_get_callback, ca_put(), ca_put_callback() etc., but not
ca_poll(), ca_pend_io() or ca_pend_event().
If you look through the CA Reference manual, those routines that can
return the code ECA_EVDISALLOW are not permitted within a callback.
> Here's an example.  A CA client creates a CA context like this:
>   status = ca_context_create(ca_enable_preemptive_callback);
> It creates a channel and then registers a state change subscription on
> it like this:
>   status = ca_create_subscription(DBR_LONG, 1, ctx->ch_image_id,
>       DBE_VALUE, on_image_id_state_change, ctx, NULL);
> And in the on_image_id_state_change callback function, it reads a PV
> value like this:
>   status = ca_get(DBR_LONG, ctx->ch_nx, &nx);
>   if (status != ECA_NORMAL) goto err;
>   status = ca_pend_io(ctx->timeout);
> Is this permissible?
The ca_get() is fine, but the ca_pend_io() is not allowed and will
return ECA_EVDISALLOW. However if you use ca_get_callback() instead of
ca_get() then you get notification that the data is available through
that callback instead.
The ca_pend_io() routine is never used in this event-driven style of
programming, where all notifications should be triggered by callback
events (even channel connections, so your program can respond
appropriately to disconnection events). The main thread can then become
a single call to ca_pend_event(0) i.e. wait forever, although in
practice it's usually more like
    while (!stop)
        ca_pend_event(0.1);
    exit(0);
to allow the application to set the stop variable and trigger a program
exit.
HTH,
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Re: Permissible in C to call CA I/O functions from callback? J. Lewis Muir
Prev: Permissible in C to call CA I/O functions from callback? J. Lewis Muir
Next: Re: Permissible in C to call CA I/O functions from callback? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
