1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Andor - Area Detector
To: "'Zenon Szalata'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Nov 2014 00:56:53 +0000
Hi Zen,
When you say "we can't acquire images" what do you mean?
- Does the frame counter in the main display increment?
- Have you enabled ArrayCallbacks in the main display?
- If so, then if you enable a statistics plugin is it getting callbacks?
- If so, are the statistics non-zero?
- If your problem is just not seeing images in a client like ImageJ, have you set EPICS_CA_MAX_ARRAY_BYTES correctly?
The obvious question is what might have changed a week or so ago?  Has the areaDetector software been rebuilt?  Have there been OS upgrades?
-----Original Message-----
Sent: Monday, November 17, 2014 5:30 PM
To: Mark Rivers; [email protected]
Subject: Andor - Area Detector
Hi Mark,
Something inexplicable is going on with our two Andor DO420A-BN-995
cameras.  All was working well until a week ago or so.  Since change
took place,  The Area Detector based IOC starts up without errors,
connects to the camera, the EDM screen shows correct values obtained
from the camera, and we can't acquire images.  I have setup one of these
cameras in my office, I give it an external trigger, no image, changing
the trigger mode to internal results in the same, no image data.  We are
using Andor SDK V2.94, Epics R3.14.12.2, asyn R4.20, ...
I have attached a console output file, which includes trace data.
I have build a few of the examples in the SDK package.  One of these is
image test program.  It generates a reasonable image file.
We also built a copy of this IOC with Epics R3.14.12.4, asyn 4.23, CALC
3.0, busy 1.6, sscan 2.9, mca 7.4, and area detector 1.9.1. This build
behaves identically as the older version.
Can you suggest how to proceed understanding and fixing this problem?
Thank you in advance,
Zen
Re: Andor - Area Detector Zenon Szalata
Prev: Andor - Area Detector Zenon Szalata
Next: Re: Andor - Area Detector Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
