1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Andor - Area Detector
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 17 Nov 2014 15:29:39 -0800
Hi Mark,
Something inexplicable is going on with our two Andor DO420A-BN-995 cameras. All was working well until a week ago or so. Since change took place, The Area Detector based IOC starts up without errors, connects to the camera, the EDM screen shows correct values obtained from the camera, and we can't acquire images. I have setup one of these cameras in my office, I give it an external trigger, no image, changing the trigger mode to internal results in the same, no image data. We are using Andor SDK V2.94, Epics R3.14.12.2, asyn R4.20, ...
I have attached a console output file, which includes trace data.
I have build a few of the examples in the SDK package. One of these is image test program. It generates a reasonable image file. We also built a copy of this IOC with Epics R3.14.12.4, asyn 4.23, CALC 3.0, busy 1.6, sscan 2.9, mca 7.4, and area detector 1.9.1. This build behaves identically as the older version.
Can you suggest how to proceed understanding and fixing this problem?
Thank you in advance,
Zen
zms@esaanal2 $ ./st.cmd
#!../../bin/linux-x86_64/andorCCD
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","sioc-esb-ada01")
epicsEnvSet("TOP","/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/iocTop/andor/test3")
epicsEnvSet("EPICS_SITE_TOP","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2")
epicsEnvSet("EPICS_MODULES","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules")
epicsEnvSet("AUTOSAVE","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/autosave/R5.0")
epicsEnvSet("ASYN","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/asyn/R4.20")
epicsEnvSet("CALC","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/calc/R2.9")
epicsEnvSet("BUSY","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/busy/R1.4")
epicsEnvSet("SSCAN","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/sscan/R2.8.1")
epicsEnvSet("MCA","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/mca/R7.0")
epicsEnvSet("AREAD","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8")
epicsEnvSet("EPICS_BASE","/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base")
errlogInit(20000)
dbLoadDatabase("../../dbd/andorCCD.dbd")
andorCCD_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PREFIX", "ANDOR1:")
epicsEnvSet("PORT",   "ANDOR")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1024")
epicsEnvSet("YSIZE",  "255")
epicsEnvSet("NCHANS", "2048")
# andorCCDConfig(const char *portName, int maxBuffers, size_t maxMemory,
#                const char *installPath, int priority, int stackSize)
andorCCDConfig("ANDOR",  0, 0, "/usr/local/etc/andor/", 0, 100000)
Constructing AndorCCD driver...
Initializing CCD...
Status thread started...
CCD initialized OK!
#andorCCDConfig("$(PORT)", 0, 0, "/usr/local/etc/andor/", 0, 0)
#andorCCDConfig("$(PORT)", 0, 0, "", 0, 100000)
Data thread started...
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/ADBase.template","P=ANDOR1:,R=cam1:,PORT=ANDOR,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFile.template","P=ANDOR1:,R=cam1:,PORT=ANDOR,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/andorCCD.template",   "P=ANDOR1:,R=cam1:,PORT=ANDOR,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "ANDOR", 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
# Make NELEMENTS in the following be a little bigger than 1024*255
# Use the following command for 32-bit images.  This is needed for 32-bit detectors or for 16-bit detectors in acccumulate mode if it would overflow 16 bits
#dbLoadRecords("$(AREAD)/ADApp/Db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=270000")
# Use the following command for 16-bit images.  This can be used for 16-bit detector as long as accumulate mode would not result in 16-bit overflow
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDStdArrays.template", "P=ANDOR1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int16,FTVL=SHORT,NELEMENTS=270000")
# moved autosave stuff here so that individual IOC can do it their way.
set_requestfile_path("./")
set_requestfile_path("../")
set_requestfile_path("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db")
set_requestfile_path("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/sscan/R2.8.1/sscanApp/Db")
#set_savefile_path("/nfs/slac/g/testfac/esb/$(IOC)/autosave")
set_savefile_path("./autosave")
Autosave is not configured to manage the file-system mount point.
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("ANDOR1:")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/autosave/R5.0/asApp/Db/save_restoreStatus.db", "P=ANDOR1:")
# Load all other plugins using commonPlugins.cmd
< ../commonPlugins.cmd
# Create a netCDF file saving plugin.
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "ANDOR", 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFile.template",      "P=ANDOR1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFileNetCDF.template","P=ANDOR1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "ANDOR", 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFile.template",      "P=ANDOR1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFileTIFF.template",  "P=ANDOR1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "ANDOR", 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFile.template",      "P=ANDOR1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFileJPEG.template",  "P=ANDOR1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1")
# Create a NeXus file saving plugin
# The default stack size on Windows in base 3.14.12.2 is only 6000 bytes, not enough for this plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "ANDOR", 0, 0, 100000)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFile.template",      "P=ANDOR1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFileNexus.template", "P=ANDOR1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "ANDOR", 0, 0, 100000)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFile.template",      "P=ANDOR1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDFileHDF5.template",  "P=ANDOR1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("$(AREAD)/ADApp/Db/NDPluginBase.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=0")
#dbLoadRecords("$(AREAD)/ADApp/Db/NDFile.template",      "P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1")
#dbLoadRecords("$(AREAD)/ADApp/Db/NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDROI.template",       "P=ANDOR1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI2", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDROI.template",       "P=ANDOR1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI3", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDROI.template",       "P=ANDOR1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI4", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDROI.template",       "P=ANDOR1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDProcess.template",   "P=ANDOR1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI1,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDStats.template",     "P=ANDOR1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=255,NCHANS=2048")
NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI2,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDStats.template",     "P=ANDOR1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=255,NCHANS=2048")
NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI3,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDStats.template",     "P=ANDOR1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=255,NCHANS=2048")
NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI4,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDStats.template",     "P=ANDOR1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=255,NCHANS=2048")
NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDStats.template",     "P=ANDOR1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=255,NCHANS=2048")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDTransform.template", "P=ANDOR1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "ANDOR", 0, 8, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template","P=ANDOR1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlay.template",   "P=ANDOR1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=ANDOR1:ROI1:MinX_RBV,YPOS=ANDOR1:ROI1:MinY_RBV,XSIZE=ANDOR1:ROI1:SizeX_RBV,YSIZE=ANDOR1:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=ANDOR1:ROI2:MinX_RBV,YPOS=ANDOR1:ROI2:MinY_RBV,XSIZE=ANDOR1:ROI2:SizeX_RBV,YSIZE=ANDOR1:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=ANDOR1:ROI3:MinX_RBV,YPOS=ANDOR1:ROI3:MinY_RBV,XSIZE=ANDOR1:ROI3:SizeX_RBV,YSIZE=ANDOR1:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=ANDOR1:ROI4:MinX_RBV,YPOS=ANDOR1:ROI4:MinY_RBV,XSIZE=ANDOR1:ROI4:SizeX_RBV,YSIZE=ANDOR1:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDOverlayN.template","P=ANDOR1:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template",   "P=ANDOR1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDColorConvert.template", "P=ANDOR1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1")
NDColorConvertConfigure("CC2", 20, 0, "ANDOR", 0, 0, 0)
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDPluginBase.template",   "P=ANDOR1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ANDOR,NDARRAY_ADDR=0")
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.8/ADApp/Db/NDColorConvert.template", "P=ANDOR1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1")
# Load scan records
dbLoadRecords("/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/sscan/R2.8.1/sscanApp/Db/scan.db", "P=ANDOR1:,MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
#set_requestfile_path("./")
#set_requestfile_path("$(AREAD)/ADApp/Db")
#set_requestfile_path("$(CALC)/calcApp/Db")
#set_requestfile_path("$(SSCAN)/sscanApp/Db")
#set_savefile_path("./autosave")
#set_pass0_restoreFile("auto_settings.sav")
#set_pass1_restoreFile("auto_settings.sav")
#save_restoreSet_status_prefix("$(PREFIX)")
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=$(PREFIX)")
asynSetTraceMask("ANDOR",0,9)
asynSetTraceIOMask("ANDOR",0,3)
iocInit()
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Jul 17 2012
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore (v4.12): entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
2014/11/14 15:48:08.664 asynPortDriver:readFloat64: function=59, value=5.000000
2014/11/14 15:48:08.664 asynPortDriver:readFloat64: function=58, value=1.000000
2014/11/14 15:48:08.664 asynPortDriver:readFloat64: function=82, value=2.000000
2014/11/14 15:48:08.664 asynPortDriver:readFloat64: function=69, value=0.000000
2014/11/14 15:48:08.664 asynPortDriver:readFloat64: function=68, value=0.000000
2014/11/14 15:48:08.669 asynPortDriver:readInt32: function=76, value=0
2014/11/14 15:48:08.669 asynPortDriver:readInt32: function=80, value=1
2014/11/14 15:48:08.676 asynPortDriver:readInt32: function=12, value=0
2014/11/14 15:48:08.676 asynPortDriver:readInt32: function=42, value=1
2014/11/14 15:48:08.676 asynPortDriver:readInt32: function=43, value=1
2014/11/14 15:48:08.676 asynPortDriver:readInt32: function=44, value=0
2014/11/14 15:48:08.677 asynPortDriver:readInt32: function=45, value=0
2014/11/14 15:48:08.677 asynPortDriver:readInt32: function=54, value=1
2014/11/14 15:48:08.677 asynPortDriver:readInt32: function=56, value=1
2014/11/14 15:48:08.677 asynPortDriver:readInt32: function=46, value=1024
2014/11/14 15:48:08.677 asynPortDriver:readInt32: function=47, value=255
2014/11/14 15:48:08.679 asynPortDriver:readInt32: function=84, value=0
2014/11/14 15:48:08.679 asynPortDriver:readInt32: function=79, value=0
2014/11/14 15:48:08.679 asynPortDriver:readInt32: function=8, value=0
2014/11/14 15:48:08.679 asynPortDriver:readInt32: function=7, value=3
2014/11/14 15:48:08.679 asynPortDriver:readInt32: function=53, value=0
2014/11/14 15:48:08.679 asynPortDriver:readInt32: function=62, value=0
recDynLinkOut: waiting for CA context
2014/11/14 15:48:08.681 asynPortDriver:readInt32: function=63, value=0
2014/11/14 15:48:08.681 asynPortDriver:readInt32: function=29, value=0
2014/11/14 15:48:08.681 asynPortDriver:readInt32: function=23, value=0
2014/11/14 15:48:08.681 asynPortDriver:readInt32: function=22, value=0
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
recDynLinkOut: got CA context
2014/11/14 15:48:09.187 asynPortDriver:readFloat64: function=37, value=0.000000
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 46891,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=ANDOR1:,D=cam1:")
save_restore:readReqFile: unable to open file andor_settings.req. Exiting.
#asynSetTraceMask($(PORT), 0, 255)
2014/11/14 15:48:09.194 andorCCDDetector:AndorCCD::writeFloat64: function=59, value=2.000000
2014/11/14 15:48:09.194 asynNDArrayDriver:writeOctet: function=15, value=
2014/11/14 15:48:09.194 asynNDArrayDriver:writeOctet: function=13, value=
2014/11/14 15:48:09.194 asynNDArrayDriver:writeOctet: function=17, value=
2014/11/14 15:48:09.194 asynNDArrayDriver:writeOctet: function=31, value=
2014/11/14 15:48:09.194 asynNDArrayDriver:writeOctet: function=81, value=
2014/11/14 15:48:09.200 andorCCDDetector:AndorCCD::writeFloat64: function=58, value=0.010000
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeFloat64: function=82, value=2.000000
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeFloat64: function=41, value=1.000000
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeFloat64: function=69, value=0.000000
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeFloat64: function=68, value=0.000000
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeFloat64: function=70, value=15.000000
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeInt32: function=76, value=0
2014/11/14 15:48:09.207 andorCCDDetector:AndorCCD::writeInt32: function=80, value=1
2014/11/14 15:48:09.212 asynPortDriver:writeInt32: function=33, value=1
2014/11/14 15:48:09.212 ADDriver:writeInt32: function=33, value=1
2014/11/14 15:48:09.213 andorCCDDetector:AndorCCD::writeInt32: function=33, value=1
2014/11/14 15:48:09.213 asynPortDriver:writeInt32: function=18, value=1
2014/11/14 15:48:09.213 ADDriver:writeInt32: function=18, value=1
2014/11/14 15:48:09.213 andorCCDDetector:AndorCCD::writeInt32: function=18, value=1
2014/11/14 15:48:09.213 asynPortDriver:writeInt32: function=21, value=1
2014/11/14 15:48:09.213 ADDriver:writeInt32: function=21, value=1
2014/11/14 15:48:09.213 andorCCDDetector:AndorCCD::writeInt32: function=21, value=1
2014/11/14 15:48:09.213 asynPortDriver:writeInt32: function=30, value=0
2014/11/14 15:48:09.213 ADDriver:writeInt32: function=30, value=0
2014/11/14 15:48:09.213 andorCCDDetector:AndorCCD::writeInt32: function=30, value=0
2014/11/14 15:48:09.214 andorCCDDetector:AndorCCD::writeInt32: function=64, value=0
2014/11/14 15:48:09.220 asynPortDriver:readInt32: function=34, value=0
2014/11/14 15:48:09.226 andorCCDDetector:AndorCCD::writeInt32: function=42, value=2
2014/11/14 15:48:09.233 andorCCDDetector:AndorCCD::writeInt32: function=43, value=5
2014/11/14 15:48:09.239 asynPortDriver:writeInt32: function=16, value=52628
2014/11/14 15:48:09.239 ADDriver:writeInt32: function=16, value=52628
2014/11/14 15:48:09.239 andorCCDDetector:AndorCCD::writeInt32: function=16, value=52628
2014/11/14 15:48:09.245 andorCCDDetector:AndorCCD::writeInt32: function=44, value=0
2014/11/14 15:48:09.251 andorCCDDetector:AndorCCD::writeInt32: function=45, value=0
2014/11/14 15:48:09.251 asynPortDriver:writeInt32: function=27, value=1
2014/11/14 15:48:09.251 ADDriver:writeInt32: function=27, value=1
2014/11/14 15:48:09.251 andorCCDDetector:AndorCCD::writeInt32: function=27, value=1
2014/11/14 15:48:09.258 andorCCDDetector:AndorCCD::writeInt32: function=54, value=1
2014/11/14 15:48:09.264 andorCCDDetector:AndorCCD::writeInt32: function=56, value=1
2014/11/14 15:48:09.271 andorCCDDetector:AndorCCD::writeInt32: function=46, value=1024
2014/11/14 15:48:09.277 andorCCDDetector:AndorCCD::writeInt32: function=47, value=255
2014/11/14 15:48:09.283 andorCCDDetector:AndorCCD::writeInt32: function=84, value=0
2014/11/14 15:48:09.283 ADDriver:writeInt32: function=83, value=0
2014/11/14 15:48:09.283 andorCCDDetector:AndorCCD::writeInt32: function=83, value=0
2014/11/14 15:48:09.284 andorCCDDetector:AndorCCD::writeInt32: function=79, value=0
2014/11/14 15:48:09.284 asynPortDriver:writeInt32: function=7, value=3
2014/11/14 15:48:09.284 ADDriver:writeInt32: function=7, value=3
2014/11/14 15:48:09.284 andorCCDDetector:AndorCCD::writeInt32: function=7, value=3
2014/11/14 15:48:09.284 asynPortDriver:writeInt32: function=20, value=0
2014/11/14 15:48:09.284 ADDriver:writeInt32: function=20, value=0
2014/11/14 15:48:09.284 andorCCDDetector:AndorCCD::writeInt32: function=20, value=0
2014/11/14 15:48:09.284 asynPortDriver:writeInt32: function=24, value=0
2014/11/14 15:48:09.284 ADDriver:writeInt32: function=24, value=0
2014/11/14 15:48:09.284 andorCCDDetector:AndorCCD::writeInt32: function=24, value=0
2014/11/14 15:48:09.284 ADDriver:writeInt32: function=52, value=0
2014/11/14 15:48:09.284 andorCCDDetector:AndorCCD::writeInt32: function=52, value=0
2014/11/14 15:48:09.293 andorCCDDetector:AndorCCD::writeInt32: function=53, value=2
2014/11/14 15:48:09.293 ADDriver:writeInt32: function=67, value=0
2014/11/14 15:48:09.293 andorCCDDetector:AndorCCD::writeInt32: function=67, value=0
2014/11/14 15:48:09.301 andorCCDDetector:AndorCCD::writeInt32: function=62, value=0
2014/11/14 15:48:09.301 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.306 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.306 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:09.387 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.387 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.387 asynPortDriver:readInt32: function=36, value=0
epics> 2014/11/14 15:48:09.487 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.487 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.487 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:09.587 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.587 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.587 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:09.687 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.687 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.688 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:09.788 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.788 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.788 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:09.888 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.888 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.888 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:09.988 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:09.988 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:09.988 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.088 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.088 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.088 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.188 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.188 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.188 asynPortDriver:readInt32: function=36, value=0
auto_settings.sav: 73 of 73 PV's connected
2014/11/14 15:48:10.288 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.288 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.288 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.388 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.389 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.389 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.489 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.489 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.489 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.589 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.589 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.589 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.689 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.689 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.689 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.790 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.791 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.791 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.889 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.889 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.889 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:10.989 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:10.989 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:10.990 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.089 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.090 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.090 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.190 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.190 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.190 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.290 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.290 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.290 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.390 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.390 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.390 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.490 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.490 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.490 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.590 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.590 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.590 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.690 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.690 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.690 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.790 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.790 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.791 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.891 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.891 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.891 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:11.991 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:11.991 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:11.991 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.091 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.091 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.091 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.191 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.191 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.191 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.291 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.291 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.292 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.391 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.391 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.391 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.492 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.492 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.492 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.592 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.592 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.592 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.692 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.692 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.692 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.792 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.792 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.792 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.892 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.892 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.892 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:12.992 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:12.992 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:12.993 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.093 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.093 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.093 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.193 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.193 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.193 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.293 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.293 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.293 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.393 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.393 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.393 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.493 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.493 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.493 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.593 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.593 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.593 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.693 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.694 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.694 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.794 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.794 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.794 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.894 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.894 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.894 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:13.994 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:13.994 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:13.994 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.094 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.094 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.094 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.194 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.194 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.194 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.294 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.295 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.295 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.395 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.395 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.395 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.495 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.495 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.495 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.595 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.595 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.595 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.695 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.695 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.695 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.795 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.795 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.795 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.895 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.895 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.896 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:14.996 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:14.996 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:14.996 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.096 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.096 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.096 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.196 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.196 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.196 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.296 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.296 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.296 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.396 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.396 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.396 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.496 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.496 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.496 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.596 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.596 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.596 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.696 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.696 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.697 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.797 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.797 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.797 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.897 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.897 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.897 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:15.997 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:15.997 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:15.997 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.097 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.097 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.097 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.197 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.197 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.197 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.297 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.297 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.297 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.397 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.397 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.397 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.497 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.498 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.498 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.598 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.598 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.598 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.698 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.698 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.698 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.798 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.798 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.798 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.898 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.898 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.898 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:16.998 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:16.998 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:16.998 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.098 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.098 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.099 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.199 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.199 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.199 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.299 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.299 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.299 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.399 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.399 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.399 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.499 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.499 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.499 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.599 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.599 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.599 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.699 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.699 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.700 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.800 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.800 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.800 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.900 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.900 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.900 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:17.000 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:17.000 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:17.000 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.103 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.103 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.103 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.200 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.200 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.201 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.300 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.300 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.300 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.401 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.401 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.401 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.501 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.501 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.501 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.601 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.601 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.601 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.701 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.701 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.701 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.801 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.801 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.801 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:18.901 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:18.901 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:18.901 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.001 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.002 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.002 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.102 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.102 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.102 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.202 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.202 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.202 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.302 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.302 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.302 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.402 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.402 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.402 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.502 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.502 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.502 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.602 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.603 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.603 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.703 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.703 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.703 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.803 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.803 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.803 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:19.903 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:19.903 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:19.903 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.003 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.003 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.003 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.103 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.103 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.103 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.203 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.203 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.204 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.304 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.304 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.304 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.404 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.404 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.404 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.504 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.504 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.504 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.604 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.604 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.604 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.704 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.704 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.704 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.804 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.804 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.804 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:20.904 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:20.905 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:20.905 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.005 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.005 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.005 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.105 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.105 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.105 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.205 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.205 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.205 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.305 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.305 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.305 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.405 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.405 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.405 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.505 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.505 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.505 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.605 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.606 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.606 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.706 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.706 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.706 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.806 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.806 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.806 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:21.906 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:21.906 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:21.906 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.006 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.006 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.006 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.106 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.106 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.106 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.206 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.206 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.206 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.306 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.306 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.307 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.406 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.407 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.407 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.507 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.507 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.507 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.607 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.607 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.607 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.707 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.707 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.707 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.807 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.807 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.807 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:22.907 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:22.907 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:22.907 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.007 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.008 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.008 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.108 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.108 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.108 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.208 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.208 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.208 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.308 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.308 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.308 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.408 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.408 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.408 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.508 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.508 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.508 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.608 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.608 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.608 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.708 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.709 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.709 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.809 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.809 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.809 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:23.909 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:23.909 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:23.909 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.009 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.009 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.009 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.109 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.109 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.109 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.209 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.209 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.209 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.309 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.309 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.309 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.409 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.410 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.410 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.510 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.510 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.510 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.610 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.610 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.610 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.710 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.710 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.710 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.810 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.810 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.810 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:24.910 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:24.910 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:24.910 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:25.010 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:25.010 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:25.010 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:25.110 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:25.110 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:25.110 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:25.150 andorCCDDetector:AndorCCD::writeInt32: function=63, value=1
2014/11/14 15:48:26.128 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.128 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.128 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.211 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.212 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.212 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.312 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.312 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.312 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.412 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.412 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.412 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.512 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.512 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.512 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.612 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.612 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.612 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.712 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.712 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.712 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.812 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.812 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.812 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:26.912 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:26.912 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:26.912 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.012 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.012 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.012 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.112 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.112 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.112 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.212 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.213 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.213 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.313 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.313 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.313 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.413 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.413 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.413 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.513 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.513 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.513 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.613 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.613 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.613 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.713 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.713 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.713 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.813 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.813 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.813 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:27.913 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:27.914 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:27.914 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.014 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.014 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.014 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.114 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.114 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.114 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.214 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.214 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.214 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.314 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.314 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.314 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.414 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.414 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.414 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.514 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.514 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.514 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.614 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.614 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.614 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.714 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.714 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.715 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.815 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.815 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.815 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:28.915 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:28.915 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:28.915 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.015 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.015 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.015 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.115 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.115 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.115 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.215 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.215 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.215 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.315 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.315 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.315 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.415 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.415 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.415 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.516 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.516 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.516 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.616 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.616 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.616 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.716 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.716 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.716 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.816 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.816 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.816 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:29.916 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:29.916 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:29.916 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.016 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.016 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.016 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.029 andorCCDDetector:AndorCCD::writeInt32: function=63, value=0
2014/11/14 15:48:30.117 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.117 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.117 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.217 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.217 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.217 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.317 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.317 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.317 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.417 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.417 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.417 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.517 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.517 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.517 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.617 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.617 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.617 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.717 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.717 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.717 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.817 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.818 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.818 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:30.918 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:30.918 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:30.918 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.018 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.018 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.018 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.118 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.118 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.118 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.218 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.218 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.218 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.318 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.318 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.318 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.418 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.418 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.418 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.518 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.518 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.518 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.618 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.618 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.618 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.719 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.719 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.719 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.819 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.819 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.819 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:31.919 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:31.922 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:31.922 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.019 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.019 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.019 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.119 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.119 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.119 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.219 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.219 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.219 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.319 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.319 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.319 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.419 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.419 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.420 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.520 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.520 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.520 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.620 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.620 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.620 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.720 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.720 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.720 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.820 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.820 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.820 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:32.920 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:32.920 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:32.920 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.020 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.020 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.021 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.121 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.121 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.121 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.221 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.221 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.221 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.321 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.321 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.321 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.421 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.421 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.421 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.521 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.521 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.521 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.621 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.621 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.621 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.721 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.721 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.721 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.821 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.821 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.822 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:33.921 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:33.922 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:33.922 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.022 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.022 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.022 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.122 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.122 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.122 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.222 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.222 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.222 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.322 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.322 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.322 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.422 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.422 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.422 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.522 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.522 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.522 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.622 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.622 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.622 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.722 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.722 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.722 asynPortDriver:readInt32: function=36, value=0
e2014/11/14 15:48:34.822 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.822 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.822 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:34.922 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:34.923 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:34.923 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:35.022 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.023 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.023 asynPortDriver:readInt32: function=36, value=0
x2014/11/14 15:48:35.123 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.123 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.123 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:35.223 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.223 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.223 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:35.323 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.323 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.323 asynPortDriver:readInt32: function=36, value=0
i2014/11/14 15:48:35.423 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.423 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.423 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:35.523 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.523 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.523 asynPortDriver:readInt32: function=36, value=0
t2014/11/14 15:48:35.623 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.623 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.623 asynPortDriver:readInt32: function=36, value=0
2014/11/14 15:48:35.723 asynPortDriver:readFloat64: function=38, value=0.000000
2014/11/14 15:48:35.723 asynPortDriver:readInt32: function=35, value=0
2014/11/14 15:48:35.723 asynPortDriver:readInt32: function=36, value=0
Shutdown and freeing up memory...
Camera shutting down as part of IOC exit.
ERROR: Driver is not initialized.
Segmentation fault
zms@esaanal2 $
RE: Andor - Area Detector Mark Rivers
Prev: RE: asynMask in asynDriver Mark Rivers
Next: RE: Andor - Area Detector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
