On Tuesday 18 November 2014 09:31:47 Janez Golob wrote:
> Hello,
> Recently I did some measurements to determine how much time a
> sequencer program needs to detect a change of a channel or en event
> flag. The two use cases are shown below:
> state wait_command
> when (start) { } state ...
> state wait_event_flag
> when (efTestAndClear(rdy_flag1)) { } state ...
> when (efTestAndClear(rdy_flag2)) { } state ...
> when (efTestAndClear(rdy_flag3)) { } state ...
> Start is an integer connected to a single channel. Rdy_flag1..3 are
> event flags associated with three arrays (each array contains around
> hundred of channels).
> My measurements show that in the first case the sequncer program
> starts executing when clause in below ms range and in the second case
> it takes around 93ms. I am getting almost the same figures on vxWorks
> (PowerPC CPU) and win32-x86 (i7 CPU) targets.
> Is this expected behavior? I would expect almost the same figure in
> both cases.
Hi Janez
your observations are interesting, but I would rather not use the word
"performance" here, as this is likely a matter of latency, rather than
burning more or less CPU cycles. (I am assuming both your test programs
contain the same channel and monitor declarations, so that there is no
extra load in the second case due to the monitor event processing.)
In your setting I would expect a somewhat higher latency for the event
flag screnario because each CA monitor event for one of the channels in
your array(s) contends for the same lock that efTestAndClear takes. But
I had not expected the difference to be that large.
It would be interesting to measure the frequency of the CA monitor
events for the channels contained in your arrays and see if there are
perhaps many such events happening at about the same time.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Andor - Area Detector Zenon Szalata
how to execute 'mcaget/mcaopen/...' command on IOCSHELL JaeRyong Seo
<2014>
2025
2026
<2014>
2025
2026
