Hi Andrew,
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 21 November 2014 18:23
> To: Abbott, Michael (DLSLtd,RAL,TEC); [email protected]
> Subject: Re: Small bug in caget
> Hi Michael,
> On 11/20/2014 05:48 AM, [email protected] wrote:
> > I've just noticed that caget incorrectly prints values of type
> > DBR_CHAR, or to be precise, the behaviour of caget depends on whether
> > the compiler is operating with signed or unsigned characters.
> This is actually the case within the IOC as well, a DBF_CHAR field (and
> the epicsInt8 C type) may be signed or unsigned depending on the ABI of
> the IOC's target architecture. I'm thus not 100% convinced whether this
> is actually a bug or not.
Interesting. I know I'd convinced myself some time ago that DBF_CHAR was unsigned, but I guess that was by inspecting some code ... and it looks as if different corners of EPICS do this differently. Certainly where I looked I found the following mappings:
CHAR 8-bit unsigned
SHORT 16-bit signed
LONG 32-bit signed
ENUM 16-bit unsigned (plus the strings)
STRING 40 8-bit bytes (indeterminate sign? haven't checked)
FLOAT 32-bit floating point
DOUBLE 64-bit floating point
That is, as I understand it, the complete list of transportable EPICS CA datatypes. However it sounds as if things aren't as well defined as I thought.
Is it worth digging deeper into the definitions of these types? I don't remember where I got the list above, but my understanding was that it was definitive ... but you're saying that things are not so clear.
> I was slightly surprised to see that the dbr_char_t is explicitly
> defined in db_access.h to be unsigned (it's a typedef for epicsUInt8),
> since dbr_short_t and dbr_long_t are both signed types. However for
> historical reasons many of our types are a bit messed up anyway, for
> example a dbr_int_t is a 16-bit quantity, reflecting the processor
> standards at the time when this code was created.
> I have looked at cleaning this kind of thing up inside the IOC at
> least,
> but it's not easy since compilers don't like passing pointers to
> unsigned char into functions such as strlen() that expect unqualified
> char pointers. We should probably have separate DBF_CHAR and DBF_INT8
> field types to distinguish whether a field should be represented as a
> character or integer value, but we don't currently.
> I will be introducing two 64-bit integer field types into the IOC
> database on the 3.16 branch which will require changes to some external
> software (the new DBF_INT64 and DBF_UINT64 values appear in the middle
> of the enum dbfType range, they can't be appended to it). I could take
> that opportunity to try fixing some of these other type issues as well
> if the community wants that and is willing to accept more breakage.
> This work would not affect CA clients though, I am not going to be
> touching that protocol or the db_access.h types which are used by
> clients.
If you're not changing CA how do you propose to transport 64-bit integers? Without CA support I don't think I understand your proposal.
- Re: Small bug in caget Andrew Johnson
- Small bug in caget michael.abbott
Re: Small bug in caget Torsten Bögershausen
Re: Defining enums to express state? Dirk Zimoch
<2014>
2025
2026
<2014>
2025
2026
