1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Small bug in caget
To: <[email protected]>, <[email protected]>
Date: Mon, 24 Nov 2014 18:08:52 -0600
On 11/24/2014 02:48 AM, [email protected] wrote:
> Interesting.  I know I'd convinced myself some time ago that DBF_CHAR was
> unsigned, but I guess that was by inspecting some code ... and it looks
> as if different corners of EPICS do this differently.  Certainly where I
> looked I found the following mappings:
> 	CHAR		8-bit unsigned
> 	SHORT		16-bit signed
> 	LONG		32-bit signed
> 	ENUM		16-bit unsigned (plus the strings)
> 	STRING	40 8-bit bytes (indeterminate sign? haven't checked)
> 	FLOAT		32-bit floating point
> 	DOUBLE	64-bit floating point
> That is, as I understand it, the complete list of transportable EPICS CA
> datatypes.
That looks correct. The STRING representation uses the native char of
the client's ABI, so the characters may be signed or unsigned.
> However it sounds as if things aren't as well defined as I thought.
Inside the IOC database we use a wider set of types and different (and
incompatible) definitions for the field index enum values DBF_STRING,
DBF_CHAR etc.
> Is it worth digging deeper into the definitions of these types?  I
> don't remember where I got the list above, but my understanding was
> that it was definitive ... but you're saying that things are not so clear.
The CA client data types are defined in db_access.h, while the IOC's
types are in dbFldTypes.h. I don't have time to explain the history of
this split right now...
>> I will be introducing two 64-bit integer field types into the IOC
>> database on the 3.16 branch which will require changes to some external
>> software (the new DBF_INT64 and DBF_UINT64 values appear in the middle
>> of the enum dbfType range, they can't be appended to it). I could take
>> that opportunity to try fixing some of these other type issues as well
>> if the community wants that and is willing to accept more breakage.
>> This work would not affect CA clients though, I am not going to be
>> touching that protocol or the db_access.h types which are used by
>> clients.
> If you're not changing CA how do you propose to transport 64-bit
> integers?  Without CA support I don't think I understand your proposal.
The V4 pvAccess protocol can transport 64-bit integer values, so this
will eventually allow them to be passed over the network natively. For
CA the DBF_INT64 and DBF_UINT64 field types will appear as DBF_DOUBLE
and automatically converted, just like DBF_ULONG fields are currently
represented.
If someone wants to look at adding 64-bit support to CA they can of
course do that, but I don't think it'll be easy [Required: Maintain
compatibility with older CA client/servers; modify both RSRV + CAS
servers; modify PV Gateway as well] and I suspect is not be worth doing
at all.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
RE: Small bug in caget michael.abbott
Re: Small bug in caget Andrew Johnson
Prev: Re: streamDevice output format question Maren Purves
Next: RE: streamDevice output format question peter.owens
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Small bug in caget michael.abbott
Next: RE: Small bug in caget michael.abbott
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
