1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: streamDevice output format question
To: <[email protected]>
Cc: [email protected]
Date: Tue, 25 Nov 2014 10:54:27 +0000
How much precision do you need, and what is the upper limit of the range?
You might be able to get away with specifying a fixed format, padded with leading zeros.
Eg.” %05.1f ml/h”
Would output
009.0 ml/h
010.0 ml/h
Pete
Sent: 24 November 2014 22:55
To: 'Dirk Zimoch'
Subject: streamDevice output format question
Dirk and all,
I have a device that requires a command of the following format:
ratei NNNNN ml/h
where NNNNN is a number that is exactly 5 characters long including the decimal point.  For example if the rate is 9 then:
ratei 9.000 ml/h
If the rate is 10 then the string must be
ratei 10.00 ml/h
If one sends 10.000 (six characters) the command is rejected.
Is there a way to achieve this with streamDevice?
I can’t use the field width flag, since that just sets a minimum field width. I need to set a maximum field width.
I realize this is a ridiculous behavior for a device, but I need to deal with it.
Scanned by iCritical.
streamDevice output format question Mark Rivers
Prev: Re: Small bug in caget Andrew Johnson
Next: MBBI Value Type Elmer Pensack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: streamDevice output format question Mark Rivers
Next: Re: streamDevice output format question Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
