Hi Mark,
Unfortunately, StreamDevice cannot solve this at the moment. I use
sprintf to format %f and thus StreamDevice can do what sprintf can do.
But you could write your own format converter in C++ and assign any
unused format character for it. StreamDevice supports adding new format
converters in a modular way.
There are more ridiculous formats in heaven and earth, Mark,
Than are dreamt of in your philosophy.
Dirk
On 24.11.2014 23:54, Mark Rivers wrote:
Dirk and all,
I have a device that requires a command of the following format:
ratei NNNNN ml/h
where NNNNN is a number that is exactly 5 characters long including the
decimal point. For example if the rate is 9 then:
ratei 9.000 ml/h
If the rate is 10 then the string must be
ratei 10.00 ml/h
If one sends 10.000 (six characters) the command is rejected.
Is there a way to achieve this with streamDevice?
I can’t use the field width flag, since that just sets a minimum field
width. I need to set a maximum field width.
I realize this is a ridiculous behavior for a device, but I need to deal
with it.
- streamDevice output format question Mark Rivers
RE: streamDevice output format question Mark Rivers
RE: Small bug in caget michael.abbott
<2014>
2025
2026
RE: streamDevice output format question peter.owens
MBBI Value Type Elmer Pensack
<2014>
2025
2026
