1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Small bug in caget
To: <[email protected]>, <[email protected]>
Date: Wed, 26 Nov 2014 10:43:28 +0000
> On 11/24/2014 02:48 AM, [email protected] wrote:
> > Interesting.  I know I'd convinced myself some time ago that DBF_CHAR
> > was unsigned, but I guess that was by inspecting some code ... and it
> > looks as if different corners of EPICS do this differently.  Certainly
> > where I looked I found the following mappings:
> > 	CHAR		8-bit unsigned
> > 	SHORT		16-bit signed
> > 	LONG		32-bit signed
> > 	ENUM		16-bit unsigned (plus the strings)
> > 	STRING	40 8-bit bytes (indeterminate sign? haven't checked)
> > 	FLOAT		32-bit floating point
> > 	DOUBLE	64-bit floating point
> > That is, as I understand it, the complete list of transportable EPICS
> > CA datatypes.
> That looks correct. The STRING representation uses the native char of
> the client's ABI, so the characters may be signed or unsigned.
In that case I don't understand why you're not 100% convinced that treating CA CHAR values as signed is a bug.  Even if the innards of the IOC are confused about this, caget can only work with values that Channel Access provides it ... so it should obey the rules of Channel Access.
> Inside the IOC database we use a wider set of types and different (and
> incompatible) definitions for the field index enum values DBF_STRING,
> DBF_CHAR etc.
I really don't understand why this is, but I guess it's historical.  I understand that the IOC has extra concepts (database links, for example), but why and how it can support data that's not transportable over CA really makes no sense to me.
However, I'm sure this is a can of worms with decades of history that I really don't want to open!
> The CA client data types are defined in db_access.h, while the IOC's
> types are in dbFldTypes.h. I don't have time to explain the history of
> this split right now...
Let's not go there.
Small bug in caget michael.abbott
Re: Small bug in caget Andrew Johnson
RE: Small bug in caget michael.abbott
Prev: Re: streamDevice output format question Dirk Zimoch
Next: edm questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Small bug in caget Andrew Johnson
Next: IOC in EPICS v4 C++ Ganesh Jangir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
