1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbboDirect vs. autosave
To: EPICS mailing list <[email protected]>
Date: Mon, 1 Dec 2014 15:17:03 -0800
A while back there were some threads discussing problems with mbboDirect record initialization.  Those problems appear to extend to autosave/restore, too.
I have an R3.14.12.3 IOC with an mbboDirect record of which I use four individual bits (4 through 7).  I originally had
record(mbboDirect, "$(P)$(R)EVR:event122trig") {
    field(DESC, "Heartbeat")
    field(DTYP, "asynUInt32Digital")
    field(OUT,  "@asynMask($(PORT) 0x37A 0xFF 0)")
    field(NOBT, "8")
    field(MASK, "0xFF")
   info(autosaveFields_pass0, "VAL")
in the database, but that didn’t seem to work.  Everything got set back to 0 on IOC startup even though the autosave life contains a non zero value (e.g. 128 or 192).
It appears that
    info(autosaveFields_pass0, "B4 B5 B6 B7 VAL”)
 works, but feels like a bit of a hack to me.
Is there any better way of handling this?
Also, a client doing a caput to an mbboDirect record .VAL field doesn’t update the .Bx fields.  I think that was discussed previously, though.
Perhaps I should just replace the mbboDirect with a longout and make clients deal with all the bit testing/setting/clearing themselves.
Eric Norum
[email protected]
Re: mbboDirect vs. autosave Andrew Johnson
Prev: EPICS Base 3.15.1 Released Andrew Johnson
Next: mbboDirect vs. autosave Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mbboDirect vs. autosave Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
