1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbboDirect vs. autosave
To: EPICS mailing list <[email protected]>
Date: Mon, 1 Dec 2014 15:28:36 -0800
Sorry for the additional message — I forgot to mention in the original posting that the record does get processed during IOC startup even though PINI=0.  When the device support makes a connection to the front end equipment it kicks off a chain of fanout records which in turn cause all the output records to process.  This mechanism also takes care of setting the values into the front end equipment when that equipment is power cycled.
A while back there were some threads discussing problems with mbboDirect record initialization.  Those problems appear to extend to autosave/restore, too.
I have an R3.14.12.3 IOC with an mbboDirect record of which I use four individual bits (4 through 7).  I originally had
record(mbboDirect, "$(P)$(R)EVR:event122trig") {
    field(DESC, "Heartbeat")
    field(DTYP, "asynUInt32Digital")
    field(OUT,  "@asynMask($(PORT) 0x37A 0xFF 0)")
    field(NOBT, "8")
    field(MASK, "0xFF")
   info(autosaveFields_pass0, "VAL")
in the database, but that didn’t seem to work.  Everything got set back to 0 on IOC startup even though the autosave life contains a non zero value (e.g. 128 or 192).
It appears that
    info(autosaveFields_pass0, "B4 B5 B6 B7 VAL”)
 works, but feels like a bit of a hack to me.
Is there any better way of handling this?
Also, a client doing a caput to an mbboDirect record .VAL field doesn’t update the .Bx fields.  I think that was discussed previously, though.
Perhaps I should just replace the mbboDirect with a longout and make clients deal with all the bit testing/setting/clearing themselves.
Eric Norum
[email protected]
Prev: mbboDirect vs. autosave Eric Norum
Next: Re: Does EPICS has defects? HaveF
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mbboDirect vs. autosave Andrew Johnson
Next: Using EPICS with Attocube stepper motor Ana Malagon
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
