1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: EPICS 3.15.1
Date: Wed, 3 Dec 2014 14:09:29 +0000
Sorry Andrew, meant to send this to the list as well:
Here are the files for one of the simpler IOC's I'm trying to produce.
I'm including the Makefile from the source directory as well, as it shows what components are being included.
>From one of your comments:
The errors you're seeing must be duplicate recordtype (not record
instance) definitions, which are no longer allowed. This means that a device support generally shouldn't have any 'include "xRecord.dbd"'
statements inside its published DBD files, but it is allowed to use empty record type declarations instead of including the record definition if all it's doing is defining device support layers:
Does that imply that converting from the 3.14 format to 3.15 prevents the software from being used on 3.14 in the future?  Will modules modified to work with 3.15's format still work correctly in the 3.14.12.2 system (what is currently being used)?
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7133
Email: [email protected]
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Tuesday, December 02, 2014 6:39 PM
To: [email protected]
Subject: Re: EPICS 3.15.1
Hi David,
On 12/02/2014 03:22 PM, Dudley, David wrote:
> Downloaded and compiled fine.
> Most of the modules we're using just needed some minor 'tweaking' to
> get working fine (actually, only about 3-4 needed changes, rest worked
> with no problems).
Thanks for the feedback there. We don't expect 3.15 to be a simple drop-in replacement for 3.14.12, so you should thoroughly test your IOCs after upgrading since there have been behaviour changes to several of the record types which could affect application functionality.
> I'm having problems with the dbdExpand.pl program.  It keeps telling
> me that I have duplicated records when I try to build my IOCS, with a
> record name of blank.
Can you post a copy/paste showing the output from make with both the commands being executed and the error messages you're getting. Also show us the content of your configure/RELEASE file so we can see which modules and the versions you're trying to build.
The new dbdExpand.pl script in 3.15 is stricter than the 3.14 dbExpand program was about what it will accept, so you will probably have to adjust the DBD files in your modules to get them to work with 3.15.
myDevice.dbd:
    recordtype(ai) {}    # optional declaration
    device(ai, INST_IO, myAiDset, "My device")
When it comes to an IOC's DBD file though, the full recordtype definition must be included before any empty recordtype declarations are seen.
This stuff is not terribly well documented yet, I'm still working on that...
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Attachment: Makefile
Description: Makefile
Attachment: RELEASE
Description: RELEASE
Attachment: text
Description: text
Re: FW: EPICS 3.15.1 Michael Davidsaver
EPICS 3.15.1 Dudley, David
Prev: Re: EPICS 3.15.1 Andrew Johnson
Next: Re: FW: EPICS 3.15.1 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
