1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FW: EPICS 3.15.1
To: [email protected]
Date: Wed, 03 Dec 2014 09:24:20 -0500
On 12/03/2014 09:09 AM, Dudley, David wrote:
> Does that imply that converting from the 3.14 format to 3.15 prevents the software from being used on 3.14 in the future?
It shouldn't and I would consider it a bug if it were.  Of course it
worst this means selecting between two .dbd files at build time.
In this instance the issue is that the BACNet module is including as.dbd
instead of asSupport.dbd, and thus pulling in two definitions of all the
Base record types.
> Context: recordtype(calcout) in file '/home/dudleyd/R3.15.1/dbd/as.dbd' in recordtype(transform) in file '/home/dudleyd/R3.15.1/dbd/transformRecord.dbd' in recordtype(scalcout) in file '/home/dudleyd/R3.15.1/dbd/sCalcoutRecord.dbd' in recordtype(acalcout) in file '/home/dudleyd/R3.15.1/dbd/aCalcoutRecord.dbd' in file '/home/dudleyd/R3.15.1/dbd/calcSupport.dbd'
>   while reading 'as.dbd' to create 'BACNetApp.dbd'
@Andrew, this message is approaching C++ template levels of hard-to-read.
EPICS 3.15.1 Dudley, David
FW: EPICS 3.15.1 Dudley, David
Prev: FW: EPICS 3.15.1 Dudley, David
Next: RE: EPICS 3.15.1 Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: FW: EPICS 3.15.1 Dudley, David
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
