Hi Saleem,
In the EPICS Makefile, you have to set the library name by setting the
base name *without the '-l' option for the linker*.
PCI7434_LIBS += pci_dask
You should also specify the location:
pci_dask_DIR = /wherever/this/library/is/located
Chapter 4 of the Application Developer's Guide has all the details.
HTH,
~Ralph
On 05/12/2014 05:54, Muhammad Saleem wrote:
Dear Dirk Zimoch,
I am writing device support for a digital output card from Adlink,
PCI-7434. Adlink ships a shared library file "libpci_dask.so" that
needs to be linked with every code we write for these DO cards. Here
is the normal gcc command line which successfully compiles a code
written for PCI-7434.
gcc -o 7434test -lpci_dask 7434test.o conio.o
I have written device support routines for this card and now I am
trying to include it in IOC. However, It gives the following error,
every time I type make.
make[3]: *** No rule to make target
`../../../lib/linux-x86/lib-lpci_dask.a', needed by `PCI7434'. Stop.
make[3]: Leaving directory `/home/muhammad/Device
Support/DevSupPCI7434/PCI7434App/src/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/muhammad/Device
Support/DevSupPCI7434/PCI7434App/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/muhammad/Device
Support/DevSupPCI7434/PCI7434App'
make: *** [PCI7434App.install] Error 2
- Error in Linking a shared library Muhammad Saleem
Moved 'ether_ip' and Matlab Channel Access 'mca' to GitHub Kasemir, Kay
<2014>
2025
2026
<2014>
2025
2026
