Hi Ralph, I've compiled 2_0_5_0 both with and without the caPutLog support on windows 7 x64, but have only checked the non-caPutLog version so far at runtime. I enclose the small changes that were required to the caPutLog and gateway code to build it, I hope to try the caPutLog support in the near future. Regards, Freddie > -----Original Message----- > From: Ralph Lange [mailto:[email protected]] > Sent: 04 December 2014 13:58 > To: EPICS Tech-Talk > Subject: CA Gateway 2.0.5.0 released > > All, > > I just uploaded a minor release of the CA Gateway [1], tagged 2.0.5.0 - > featuring > * 3.15 compatibility: compiles against 3.14.11+ and 3.15.1 > * Support for the CaPutLog module to log CA put operations, using the > same library as the IOC [2] > (thanks to FRIB for this contribution) > > It seems that Windows builds have been broken for a while - they still are. > If you are in production, I would think the update is of low priority, > unless you want to use the CA Put Log support. > > Source tar available at > https://launchpad.net/epics- > gateway/trunk/2.0.5.0/+download/gateway2_0_5_0.tar.gz > > Next things in the Gateway pipeline include: > - Make it a standard self-contained EPICS TOP module > - Deprecate the built-in watchdog/restart in favor of using procServ [3] > - Add integration testing (SLAC started working on this) > - Support DBE_PROPERTY event flag (SLAC started working on this) > - Resurrect Windows build (volunteers?) > > Cheers, > ~Ralph > > [1] http://launchpad.net/epics-gateway > [2] http://www-csr.bessy.de/control/SoftDist/caPutLog/ > [3] http://sourceforge.net/projects/procserv/ Attachment:
caPutLog34.diff Attachment:
gateway2_0_5_0.diff
| ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
