1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Gateway 2.0.5.0 released
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Fri, 12 Dec 2014 10:22:06 -0600
Hi Freddie,
On 12/12/2014 09:26 AM, [email protected] wrote:
> I've compiled 2_0_5_0 both with and without the caPutLog support on
> windows 7 x64, but have only checked the non-caPutLog version so far
> at runtime.  I enclose the small changes that were required to the
> caPutLog and gateway code to build it, I hope to try the caPutLog
> support in the near future.
Do you really need to change the calling conventions for those
functions? The epicsShareApi macro expands to __stdcall which makes the
generated code use Pascal calling conventions instead of the C ones. I
suspect you meant to mark them with epicsShareFunc instead, which
expands to the appropriate __declspec(dll*port) attribute.
I have been trying to remove the use of epicsShareApi from the EPICS
APIs in the last few years, is there some reason to reverse that?
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
RE: CA Gateway 2.0.5.0 released freddie.akeroyd
CA Gateway 2.0.5.0 released Ralph Lange
Prev: RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Next: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CA Gateway 2.0.5.0 released freddie.akeroyd
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
