1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception
To: Walter Werner <[email protected]>, <[email protected]>
Date: Fri, 12 Dec 2014 10:44:57 -0600
On 12/12/2014 10:28 AM, Walter Werner wrote:
> I use pyepics for my client and want to avoid the "Virtual circuit
> disconnect" exception from CA being printed on the standard input.
> CA.Client.Exception...............................................
>     Warning: "Virtual circuit disconnect"
>     Context: "localhost:20000"
>     Source File: ../cac.cpp line 1215
>     Current Time: Wed Dec 10 2014 05:51:45.821307011
> This exception accrues if the server is down.
Do you have a connection callback handler for your PVs? If not,
supplying one may prevent some of the disconnect messages (and permit
your code to find out when it should stop trying to access the PV values).
You can also redirect any/all error messages from the underlying CA
library by providing your own printf handler. From the pyepics
documentation for the low-level CA module:
> epics.ca.replace_printf_handler(fcn=None)
>   Replace the normal printf() output handler with the supplied
>   function (defaults to sys.stderr.write())
Note that a single message like the one you quoted above may have come
from several calls to the printf handler routine, so don't just try to
pop up a new dialog box every time it gets called.
HTH,
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Prev: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Next: RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
