1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception
To: [email protected]
Date: Mon, 15 Dec 2014 15:43:40 +0100
supplement
> Do you have a connection callback handler for your PVs? If not,
> supplying one may prevent some of the disconnect messages (and permit
> your code to find out when it should stop trying to access the PV values).
In my simple example i tried to add the callback handler, but the CA
message is still printed. My version of pyepics is 3.2.3.
best regards
  Walter
Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Matt Newville
pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
Prev: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Next: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
Next: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Matt Newville
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
