1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception
To: Walter Werner <[email protected]>, <[email protected]>
Date: Mon, 15 Dec 2014 10:25:55 -0600
Hi Walter,
On 12/15/2014 08:22 AM, Walter Werner wrote:
> 2014-12-12 17:44 GMT+01:00 Andrew Johnson <[email protected]>:
>> Do you have a connection callback handler for your PVs? If not,
>> supplying one may prevent some of the disconnect messages (and permit
>> your code to find out when it should stop trying to access the PV values).
> Yes, i do have the connection handler. And i try to recoonect the pv
> if the connection is lost. As far as i know the PV class does not
> reconnect automatically. My problem was more a cosmetic nature for the
> end user. It looks not very nice if some exception is printed on the
> console, although i already take care of it.
I'm not a pyepics expert so I might be wrong about how to use it, but
the underlying CA library *does* reconnect channels automatically as
soon as the IOC comes back online, so you might want to double-check
that part of your code just to make sure.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Prev: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Next: Re: CA Gateway 2.0.5.0 released Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Fwd: Undelivered Mail Returned to Sender Ron Sluiter
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
