1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems building EPICS base3.14.12.4 for i386 and armhf
To: EPICS Tech Talk <[email protected]>
Date: Wed, 07 Jan 2015 10:30:16 +0100
Hey all,
for the PANDA experiment (which is still in development/prototyping phase)
we wanted to create Debian packages to simplify the maintainability of our current EPICS installations.
I oriented myself by the Debian packages from Michael Davidsaver and
added these compiler flags in my debian rules file for the build process:
DEB_USR_CXXFLAGS:=$(shell dpkg-buildflags --get CXXFLAGS)
DEB_USR_CFLAGS:=$(shell dpkg-buildflags --get CFLAGS)
DEB_USR_CPPFLAGS:=$(shell dpkg-buildflags --get CPPFLAGS)
DEB_USR_LDFLAGS:=$(shell dpkg-buildflags --get LDFLAGS)
The packages should be build for the architectures amd64, i386 and armhf.
For amd64 everything works smoothly. But for the other two I got lots of warnings
when compiling Cap5.c from base3.14.12.4 (see log below)
Additionally the above compiler flags include "-Werror=format-security"
which causes the compilation of Cap5.c to fail with an error.
Is there a way to fix this problem without removing the compiler flags?
Best regards
Florian
perl /usr/bin/xsubpp -typemap /usr/share/perl/5.14/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c /usr/bin/gcc -c -D_FORTIFY_SOURCE=2 -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_FORTIFY_SOURCE=2 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fstack-protector -fno-strict-aliasing -pipe -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I/home/florian/dpack/tmp/epics-base-3.14.12.4/debian/epics-base/include/os/Linux -I/home/florian/dpack/tmp/epics-base-3.14.12.4/debian/epics-base/include -I/usr/lib/perl/5.14/CORE Cap5.c
../Cap5.xs: In function ‘CA_new’:
../Cap5.xs:445:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] ../Cap5.xs:464:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_DESTROY’:
../Cap5.xs:475:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:493:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_change_connection_event’:
../Cap5.xs:508:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:518:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_put’:
../Cap5.xs:527:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:602:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_put_callback’:
../Cap5.xs:617:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:697:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_put_acks’:
../Cap5.xs:707:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:738:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_put_ackt’:
../Cap5.xs:748:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:762:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_get’:
../Cap5.xs:771:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:790:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_value’:
../Cap5.xs:798:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_get_callback’:
../Cap5.xs:817:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:871:5: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_create_subscription’:
../Cap5.xs:884:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:944:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] ../Cap5.xs:953:5: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_clear_subscription’:
../Cap5.xs:960:18: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ../Cap5.xs:970:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_pend_io’:
../Cap5.xs:980:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_pend_event’:
../Cap5.xs:995:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_add_exception_event’:
../Cap5.xs:1083:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_replace_printf_handler’:
../Cap5.xs:1141:9: error: format not a string literal and no format arguments [-Werror=format-security]
../Cap5.xs: In function ‘CA_field_type’:
../Cap5.xs:1149:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_element_count’:
../Cap5.xs:1160:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_name’:
../Cap5.xs:1168:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_state’:
../Cap5.xs:1176:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_is_connected’:
../Cap5.xs:1187:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_host_name’:
../Cap5.xs:1195:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_read_access’:
../Cap5.xs:1203:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
../Cap5.xs: In function ‘CA_write_access’:
../Cap5.xs:1211:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
cc1: some warnings being treated as errors
make[5]: *** [Cap5.o] Error 1
make[5]: Leaving directory `/home/florian/dpack/tmp/epics-base-3.14.12.4/src/cap5/O.linux-x86'
make[4]: *** [install.linux-x86] Error 2
make[4]: Leaving directory `/home/florian/dpack/tmp/epics-base-3.14.12.4/src/cap5'
make[3]: *** [cap5.install] Error 2
make[3]: Leaving directory `/home/florian/dpack/tmp/epics-base-3.14.12.4/src'
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `/home/florian/dpack/tmp/epics-base-3.14.12.4'
dh_auto_build: make -j1 USR_CFLAGS_Linux=-fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security USR_CXXFLAGS_Linux=-fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security USR_CPPFLAGS_Linux=-D_FORTIFY_SOURCE=2 USR_LDFLAGS_Linux=-Wl,-z,relro -Wl,--as-needed returned exit code 2
make[1]: *** [override_dh_auto_build] Error 2
make[1]: Leaving directory `/home/florian/dpack/tmp/epics-base-3.14.12.4'
make: *** [build] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
debuild: fatal error at line 1357:
dpkg-buildpackage -rfakeroot -D -us -uc -i -I failed
gbp:error: Couldn't run 'debuild -i -I': debuild -i -I returned 29
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Re: Problems building EPICS base3.14.12.4 for i386 and armhf Jani Hakala
Re: Problems building EPICS base3.14.12.4 for i386 and armhf Andrew Johnson
Prev: Re: Installing CaLab "V.1.2.1.5" on SL6.1 Jani Hakala
Next: Re: Problem building asyn R4-25 on Mac OSX Yosemite Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem building asyn R4-25 on Mac OSX Yosemite Mark Rivers
Next: Re: Problems building EPICS base3.14.12.4 for i386 and armhf Jani Hakala
