Florian Feldbauer <[email protected]> writes:
> The packages should be build for the architectures amd64, i386 and armhf.
> For amd64 everything works smoothly. But for the other two I got lots
> of warnings
> when compiling Cap5.c from base3.14.12.4 (see log below)
> Additionally the above compiler flags include "-Werror=format-security"
> which causes the compilation of Cap5.c to fail with an error.
> Is there a way to fix this problem without removing the compiler flags?
You could try modifying file Cap5.xs by replacing instances of
croak(get_error_msg(status));
with
croak("%s", get_error_msg(status));
This kind of change is in essence suggested in
https://fedoraproject.org/wiki/Format-Security-FAQ
Jani Hakala
- Problems building EPICS base3.14.12.4 for i386 and armhf Florian Feldbauer
Re: Can't start CSS RDB archiver zunbeltz
Re: Problems building EPICS base3.14.12.4 for i386 and armhf Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
