1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Can't start CSS RDB archiver
Date: Wed, 7 Jan 2015 16:45:43 +0000
>The start() methods are the same in my version and the one in github.
>Lines 115-117 are:
>         thread = new Thread(this, "WriteThread");
>         output.println("time to start: "+ currentData());
>         thread.start();
>I guess that the error is in the new Thread line because 116 line is
>composed of standard library functions (as far as my poor java knowledge
>helps).
>Am  i correct or shuld I look if the currentData() is not working fine?
    If currentData or the Thread constructor were the issue you would see the method
calls in the unwinding of the stack. You have a NullPointerException which means you are
trying to access member data of something that was never given a value. In this case,
the only possible culprit is 'output'. Try to find where the variable 'output' is instantiated
in the code.
Prev: Re: Problems building EPICS base3.14.12.4 for i386 and armhf Andrew Johnson
Next: Re: Can't start CSS RDB archiver Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Can't start CSS RDB archiver Kasemir, Kay
Next: send css browser data to web l123173
