1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
To: Mark Rivers <[email protected]>, "[email protected] ([email protected])" <[email protected]>
Date: Fri, 09 Jan 2015 16:39:55 +0100
Marc,
thank you for your quick answer.
I am running base-3.15.1-rc1
areaDetector just downloaded today from the git-master, so I assume R2-1 with
ADCore also downloaded today is R2-2
h1@earth:~/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC$ pwd
/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC
h1@earth:~/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC$ make clean uninstall
make -C ./configure clean
make[1]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure'
rm -rf O.linux-x86_64 O.Common
make[1]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure'
make -C ./simDetectorApp clean
make[1]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp'
make -C ./Db clean
make[2]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db'
make[2]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db'
make -C ./src clean
make[2]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make[2]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src' make[1]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp'
make -C ./iocBoot clean
make[1]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot'
make -C ./iocSimDetector clean
make[2]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot/iocSimDetector'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
make[2]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot/iocSimDetector' make[1]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot'
rm -rf ./bin/linux-x86_64
rm -rf ./lib/linux-x86_64
make[1]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC'
rm -rf ./bin
rm -rf ./lib
make[1]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC' rm -rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg ./edl ./lib/perl ./lib/pkgconfig
make -C ./configure install
make[1]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure' perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure/O.linux-x86_64' perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure/O.linux-x86_64' make[1]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure'
make -C ./simDetectorApp install
make -C ./Db install
make[2]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db' perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db/O.linux-x86_64' make[2]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db'
make -C ./src install
make[2]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src' perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make[3]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/h1/EPICS/base/include/compiler/gcc -I/home/h1/EPICS/base/include/os/Linux -I/home/h1/EPICS/base/include -I/home/h1/EPICS/support/asyn4-25/include -I/home/h1/EPICS/support/areaDetector/ADCore/include -I/home/h1/EPICS/support/calc-3-4/include -I/home/h1/EPICS/support/busy-1-6-1/include -I/home/h1/EPICS/support/sscan-2-10/include -I/home/h1/EPICS/support/autosave-5-5/include/os/Linux -I/home/h1/EPICS/support/autosave-5-5/include -MM -MF simDetectorAppMain.d ../simDetectorAppMain.cpp
Creating dbd file simDetectorApp.dbd
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd -I/home/h1/EPICS/support/asyn4-25/dbd -I/home/h1/EPICS/support/areaDetector/ADCore/dbd -I/home/h1/EPICS/support/calc-3-4/dbd -I/home/h1/EPICS/support/busy-1-6-1/dbd -I/home/h1/EPICS/support/sscan-2-10/dbd -I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd dbdExpand.pl: Leaving context "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'", found "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'" instead.
Context: file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'
  while reading 'commonDriverSupport.dbd' to create 'simDetectorApp.dbd'
dbdExpand.pl: Exiting due to errors
Context: file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd' while reading 'commonDriverSupport.dbd' to create '../O.Common/simDetectorApp.dbd.d' make[3]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64' make[3]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
make[3]: *** [../O.Common/simDetectorApp.dbd] Error 255
make[2]: *** [install.linux-x86_64] Error 2
make[1]: *** [src.install] Error 2
make: *** [simDetectorApp.install] Error 2
On 09.01.2015 16:16, Mark Rivers wrote:
I have never encountered this error.  What version of areaDetector and what version of EPICS base are you using?
This is the command that was executing for you when building for linux-x86_64 in that directory:
make[6]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
This is the command that was executing for me:
make[3]: Entering directory `/home/epics/devel/areaDetector-2-1/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
perl /corvette/usr/local/epics/base-3.14.12.4/bin/linux-x86_64/makeIncludeDbd.pl simDetectorSupport.dbd commonDriverSupport.dbd simDetectorAppInclude.dbd
echo "../O.Common/simDetectorAppInclude.dbd : ../Makefile" >> simDetectorApp.dbd.d
Expanding dbd
Installing created dbd file ../../../dbd/simDetectorApp.dbd
Note that your perl command has a "-CSD" flag and yours is executing "dbdExpand.pl" while mine is executing "makeIncludeDbd.pl".  I am running ADCore R2-2 pre-release (but basically the same as R2-1) and EPICS base 3.14.12.4.  Just before I ran "make" I ran "make clean uninstall" in the simDetectorIOC directory.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Heinz Junkes
Sent: Friday, January 09, 2015 8:58 AM
To: [email protected] ([email protected])
Subject: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
running into following trouble:
make[5]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make[6]: *** [../O.Common/simDetectorApp.dbd] Error 255
make[6]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
make[5]: *** [install.linux-x86_64] Error 2
make[5]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make[4]: *** [src.install] Error 2
and don't know how to fix it ;-)
Where should I look? Which file may really cause the error?
Cheers,
Heinz
RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz Junkes
Prev: RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
Next: RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
