1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: exit puzzle about SNL's example
To: tech-talk <[email protected]>
Date: Mon, 12 Jan 2015 12:52:53 +0800
hi,
On the website of EPICS Sequencer Home, there are several examples about SNL which use exit in two places.
The first one is in the example "Entry and exit action example" ,that exit part will execute one time when the state changes from high to low. and, if use "option -e" switch, the entry will be executed each time, not as expected. Without "option -e" switch, it will run as the document's behavior, did I make some mistake?
The second one is in the “Complex example “ (http://www-csr.bessy.de/control/SoftDist/sequencer/Examples.html#exit-procedure)
Exit is a separate part out of state set, I am wondering when that exit procedure will be executed?
Thanks a lot for your help.
Best wishes
Geyang 2015-01-12
Re: exit puzzle about SNL's example Benjamin Franksen
Prev: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Andrew Johnson
Next: Re: What happened to "dbNameOfPV" in EPICS 3.15.1 : Need this for caPutLog Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer release 2.1.18 Benjamin Franksen
Next: Re: exit puzzle about SNL's example Benjamin Franksen
