1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
To: Mark Rivers <[email protected]>, "'Mooney, Tim M.'" <[email protected]>, "'Heinz P. Junkes'" <[email protected]>, "[email protected] ([email protected])" <[email protected]>
Date: Fri, 9 Jan 2015 18:11:32 -0600
Hi Mark,
On 01/09/2015 06:07 PM, Mark Rivers wrote:
> I have found and fixed the problem.
> The problem was that NDPluginSupport.dbd was lacking a trailing
> newline on the last line.  This problem was introduced recently when
> the new NDPluginCircularBuffer plugin was added.
> The EPICS 3.14.12.4 build system is tolerant of this problem.  The
> EPICS 3.15.1 build system is not.
I will fix that so it is, thanks for tracking it down.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz Junkes
RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz P. Junkes
Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Andrew Johnson
RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mooney, Tim M.
Prev: RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
Next: exit puzzle about SNL's example Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: sequencer release 2.1.8 Benjamin Franksen
