Sorry, this is a newbie Epics question: I'm working on making an IOC for a fieldfox network analyzer (model KT-N9918A) and need to cut off the number of values returned in a 'read measurement' command based on the number of points in the measurement, but I'm not sure how to go about doing this. I have one record to store the number of points in the measurement, and another record that reads in the measurement values - how would I go about incorporating the number of points in the 'read measurement' record? Here is how I've defined the read measurement command: /* Param 18 -- Read S21 Format: (Re,Im) dB */ {&DSET_WF, GPIBREAD, IB_Q_HIGH, ":CALC1:PAR1:DEF S21;:CALC1:PAR1:SEL;:CALC1\ :SEL:DATA:SDAT?", NULL, 0, 1E6, readWF, 0, 0, NULL, NULL, NULL} and here is the query of the points: /* Param 21 - Get Points in Sweep */ {&DSET_AI, GPIBREAD, IB_Q_HIGH, ":SENS1:SWE:POIN?", NULL, 0, 100, readData, 0, 0, N\
ULL, NULL, NULL}, where the conversion function readWF is defined as: static int readWF(struct gpibDpvt *pdpvt,int P1, int P2, char**P3) { struct waveformRecord *pwf=(struct waveformRecord *)pdpvt->precord; asynUser *pasynUser = pdpvt->pasynUser; double* value = (double *)pwf->bptr; const char* cpymsg = pdpvt->msg; double data; int n; pwf->nord=0; while ((pwf->nord < pwf->nelm) && sscanf(cpymsg,"%lE,%n",&data,&n)==1) { if (P1==1) data/=1E6; if (P1==2 && (pwf->nord==0 || pwf->nord==1)) data/=1E6; memcpy(value+pwf->nord,&data,sizeof(double)); pwf->nord++; cpymsg+=n; asynPrint(pasynUser,ASYN_TRACE_FLOW,"(NORD,VAL) : (%i,%E)\n",pwf->nord,data); \
} if (pwf->nord == 0) return -1; pwf->udf = 0; return 0;
} the readData conversion function is: static int readData(struct gpibDpvt *pdpvt,int P1, int P2, char**P3) { struct aiRecord *pai=(struct aiRecord *)pdpvt->precord; printf("got: %s\n",pdpvt->msg); double meas =(double)atof(pdpvt->msg); pai->val = meas; pai->udf = 0; return 0; } and the database definition entry for the read measurement comand is below, where NELM was defined to be 2x the maximum number of points one can request in a measurement: record(waveform, "$(P):S21") { field(DESC, "S21 (Re,Im)") field(EGU,"dB") field(SCAN, "Passive") field(NELM, "20002") field(DTYP, "fieldfox") field(FTVL, "DOUBLE") field(INP, "#L$(L) A$(A) @18") field(FLNK, "$(P):FREQ") field(DISV, "0") field(SDIS, "$(P):OPC.VAL PP")
} The reason I need to cut off the values is because the current syntax in the read measurement command not only returns the measurement data but also the x-axis values, which I don't want. Sorry again for the very basic question, and thanks! Ana Malagon
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
