1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer release 2.2.1
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 26 Jan 2015 15:02:51 +0000
On Mon, 2015-01-26 at 14:02 +0100, Benjamin Franksen wrote:
> The perl version is fine, I have been running the tests on a debian 4
> with perl 5.8.8. But the version of Test::More that comes with these old
> distributions does not yet have support for subtests, which is why you
> get the strange error message.
> If you want to run the compiler tests, you should install a more recent
> version of Test::More. In RHEL the package is named perl-Test-Simple.
> The simplest solution would be to install a backport for your distro (if
> you can get your hands on one). Failing that, you could install it
> manually via CPAN.
> I think there is not much more I could do, except perhaps include a test
> for the version of Test::More in the script and bail out if subtests are
> not supported.
> Cheers
> Ben
Thanks. I'll just run without the compiler checks.
Paul.
sequencer release 2.2.1 Benjamin Franksen
Re: sequencer release 2.2.1 Benjamin Franksen
Re: sequencer release 2.2.1 Paul Hamadyk
Prev: Checking which record triggered processing Tobiasz Czopowicz
Next: RE: Checking which record triggered processing Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer release 2.2.1 Benjamin Franksen
Next: calling the output of one record into another record Ana Malagon
