Hi Mark, Thanks - I've moved over to StreamDevice and now have a very simpleminded question. I've created a test application following the instructions here; make runs successfully in my top directory. When I run st.cmd, however, I get a 'no reply from device with 1000 ms'. I believe I'm using up to date versions of asyn (4.22), stream (2.6), and base (3.14). I'm sure I'm missing something obvious - is there some other setup step that I should have done? Below is the output from st.cmd - Thanks, Ana admx@admxcontrol:~/admxepics/devices/fieldfoxstream/iocBoot/iocFIELDFOXSTREAMtest$ ./st.cmd #!../../bin/linux-x86_64/FIELDFOXSTREAMtest ## You may have to change FIELDFOXSTREAMtest to something else ## everywhere it appears in this file < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocFIELDFOXSTREAMtest") epicsEnvSet("TOP","/home/admx/admxepics/devices/fieldfoxstream") epicsEnvSet("ASYN","/home/admx/epics/asyn4-22") epicsEnvSet("STREAM","/home/admx/epics/StreamDevice-2-6") epicsEnvSet("EPICS_BASE","/home/admx/epics/base-3.14.12.4") epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/admx/admxepics/devices/fieldfoxstream/db" epicsEnvSet "P" "fieldfoxstream" epicsEnvSet "R" "Test" cd /home/admx/admxepics/devices/fieldfoxstream ## Register all support components dbLoadDatabase "dbd/FIELDFOXSTREAMtest.dbd" FIELDFOXSTREAMtest_registerRecordDeviceDriver pdbbase drvAsynIPPortConfigure("L0", "10.95.101.76:5025", 0, 0, 0) asynOctetSetInputEos("L0", 0, "\n") st.cmd line 18: Command asynOctetSetInputEos not found. asynOctetSetOutputEos("L0", 0, "\n") st.cmd line 19: Command asynOctetSetOutputEos not found. asynSetTraceIOMask("L0", -1, 0x2) st.cmd line 20: Command asynSetTraceIOMask not found. asynSetTraceMask("L0", -1, 0x9) st.cmd line 21: Command asynSetTraceMask not found. ## Load record instances dbLoadRecords("db/devFIELDFOXSTREAM.db","P=fieldfoxstream, R=Test, PORT=L0, A=0") cd /home/admx/admxepics/devices/fieldfoxstream/iocBoot/iocFIELDFOXSTREAMtest iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$ ## EPICS Base built May 20 2014 ############################################################################ cas warning: Configured TCP port was unavailable. cas warning: Using dynamically assigned TCP port 43138, cas warning: but now two or more servers share the same UDP port. cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=admxHost" epics> 2015/01/15 11:20:44.557860 L0 fieldfoxstreamTestIDN: No reply from device within 1000 ms 2015/01/15 11:20:45.559805 L0 fieldfoxstreamTestIDNwf: No reply from device within 1000 ms On Wed, Jan 14, 2015 at 12:03 PM, Mark Rivers <[email protected]> wrote:
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
