1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Alarm annunciation with ALH and other PC based systems
To: Rod Nussbaumer <[email protected]>, EPICS mailing list <[email protected]>
Date: Tue, 20 Jan 2015 15:43:28 -0800
Interesting thread.
If I understand your email correctly, you are using the old ALH on a PC.
Well, if you are sticking with this setup then the best way may be to dedicate a computer to run the ALH
and put it behind a glass so that no one can touch it! Put the speakers out of reach as well.
Are you open to using something else other than the ALH?
Emmanuel Mayssat
http://www.epicsqt.org
> Date: Wed, 14 Jan 2015 13:27:14 -0800
> From: [email protected]
> To: [email protected]
> Subject: Alarm annunciation with ALH and other PC based systems
> Hi All:
> Sorry that this isn't really an EPICS question, other than the tenuous
> connection via Alarm Handler.
> The question has been raised here about how to ensure that the audible
> alarms from Alarm Handler are always audible. A number of places exist
> where this can be disabled. The speakers can become faulty, the
> wall-wart commonly used to power the speakers can become disconnected or
> faulty, the volume control on the speakers can be turned down, the host
> OS software controls can be turned down or muted either through accident
> or software fault, audio cables can become faulty, and sound card
> hardware can become faulty. Most of these will manifest only in silence.
> Has anyone undertaken measures to monitor any of these components in
> some way, or implemented hardware which is not subject to the common
> frailties of commodity audio equipment used for control room alarms?
> Any suggestions cheerfully accepted. Thanks.
> Rod Nussbaumer
> E-Linac Controls, TRIUMF
> Vancouver, Canada.
Re: Alarm annunciation with ALH and other PC based systems Maren Purves
Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
Prev: Re: how to choose port of digitizer for IOC? Ana Malagon
Next: building edm on 64-bin debian Ana Malagon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Alarm annunciation with ALH and other PC based systems austen.rose
Next: Re: Alarm annunciation with ALH and other PC based systems Maren Purves
