1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using asynDriver outside of an EPICS IOC
To: "'Emmanuel Mayssat'" <[email protected]>, Jimmy Johnson <[email protected]>, EPICS mailing list <[email protected]>
Date: Mon, 26 Jan 2015 22:48:53 +0000
> Or are you saying that asyn can be used to interface with hardware in any other control system?
The main motivation for using asyn in another control system would be to take advantage of drivers that have been written using asyn.  This includes areaDetector and supports for lots of other hardware.
As Andrew said, both the asyn core (asynManager) and the existing asyn drivers use libCom for mutexes, queues, etc.  The alternative would be boost or something similar, but libCom is very portable (does boost run on vxWorks and RTEMS?) and it is what the existing asyn code uses.
Sent: Monday, January 26, 2015 12:35 PM
To: Jimmy Johnson; EPICS mailing list; Mark Rivers
Mark,
I am interested in that topic as well.
I just want to understand correctly.
Are you saying that an EPICS database can be populated with data coming from another control system?
In this latter case, why even depend on libCom from the EPICS base then?
Emmanuel Mayssat
http://www.epicsqt.org
To: [email protected]
Subject: Using asynDriver outside of an EPICS IOC
Date: Thu, 22 Jan 2015 18:48:11 +0000
Has anyone used the asynDriver framework outside of an EPICS IOC and if so would you be willing to share your experience?
Thanks
Jimmy Johnson
Using asynDriver outside of an EPICS IOC Jimmy Johnson
RE: Using asynDriver outside of an EPICS IOC Emmanuel Mayssat
Prev: Re: Problem building epics base under CentOS 5.6 Andrew Johnson
Next: RE: setting interpreter in EPICS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using asynDriver outside of an EPICS IOC Andrew Johnson
Next: Problem building epics base under CentOS 5.6 GONG Yu
